Hi
Daniel
F21 error means that the drain time has exceeded 8
minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to
clear the display. If errors still remains then please check the drain hose and
make sure it is not plugged or kinked. Disassemble the washer by removing the
back from the washer and check the electrical connections at the pump and make
sure the pump is draining. Also inspect the pump filter for foreign objects.
Before disassembling remember to turn off the power and disconnect the washer.
If it still doesn't help then there is an issue with the pump and you'll need
to replace it. F22 error is a door lock error, if you have already replaced the
complete door lock assembly and the issues is still there then check the wire
harness connections to the door switch/lock Unit and Central Control Unit
(CCU). If the wire harness is fine then the issue is with CCU that should be
replaced. Hope this helps... Please post back if you need more
information.
