SOURCE: 83 PHOTODEV CART MISSING
To specify which supply has been replaced:
SOURCE: Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Put a piece of masking tape on the sides of the little window on the cartridge. That will make the machine think all cartridges are full all the time.
SOURCE: Error 1681 more than one Cyan cartridge installed
I have just tried this solution and it has worked (hum, for how long ?) :
Turn your printer off.
Keep pushed the middle button for about 6 seconds (the one that is blinking in yellow, seven times for the error 1681)
Your printer should turn on and work again.
Hope it will solve your / my problem.
Sorry for my poor english
Francois
SOURCE: Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
SOURCE: purchased new fusing unit for ricoh cl3500n;
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Memory chip at TD sensor: Communication error
Retry of memory chip communication fails three times after the
machine has detected the memory chip communication error.
?? Damaged memory chip data
?? Disconnected inter face
?? No memory chip on the development unit
?? Noise
Replace the PCU.
1. Defective electrical connection for the TD sensor.
2. TD sensor not installed correctly
1. Take out the dev unit
and put it back in. If that
does not work, replace
the dev unit.
2. Press the TD sensor
firmly against the frame
of the development unit.
