2004 Saturn ION Logo
Posted on Aug 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My trunk won't open, I have tried my trunk button and the key won't work, it worked fine a few hours, but even when i try to do it manually it won't open. Also I would look in and try the emergency release lever, but you have to push a button from the trunk to lower the seats
Archaeology
Level 3:
President:
  • Master 662 Answers
  • Posted on Aug 15, 2011
Archaeology
Master
Level 3:
President:
Answers
662
Questions
8
Helped
495996
Points
2068
There are 3 phases to fixing your car's trunk lid release problem.
Phase 1: First check the fuse - once you know that's OK, then proceed to phase 2 (below).
The fuse for the trunk lock is
the bcm (pwr) 15A fuse in the instrument panel fuse box (behind panel at drivers right foot)
Check that fuse, as it is the power supply for the button on the dash that sends power to the actuator in the trunk.
Phase 2: Get the trunk open (without taking it to the dealership).
If you have remote keyless entry to the trunk, you could try that - but with the actuator
dead/dying, it shouldn't work.
Here are a couple of ideas to try to enter trunk while (a) actuator isn't working, and (b) all
valet lockout features (designed to deny valets access to the trunk) are in the "Lock" position:
There is the lock cylinder, which you stated is not functioning - put the key in, and it doesn't
turn. Just to be sure, consider: lubricate key with Graphite lock-type lubricant, and retry.
The trunk has 2 valet safetys...the locking rear seats which require access to the trunk to unlock, and then there is a valet switch in the trunk that locks the button on the dash from working to keep valet parking attendants out of the trunk. That may be in the lock position.
You can try accessing the center area of the fold down rear seat and see if you can unhinge the rear seat from there. Maybe reach in with your hand, or an extension-type tool.
there may be a way to fold the hinge away from the seat back so it can be removed from the hinge and give you access to the safety latch in the trunk and open it that way (white handle in trunk).
The white-handled safety latch release is desiged to prevent accidentally trapping children, and
if you can pull it with your extending-type or grasping-type tool, the trunk will open whether or
not the actuator motor is working.
Phase 3: Replace the Problem part.
Your failed part may be either (1) Trunk Release Relay, or (2) Trunk Lock Release Switch
My Satrun ION manual doesn't cover either of these parts, and the online parts houses, e.g.
http://www.rockauto.com/catalog/x,carcode,1431624,pgname,Electrical-Switch%2B%2526%252338%253B%2BRelay,a,search.yahoo.com%2BSearch%2Bfor%2B2004%2BSATURN
fail to provide instructions. One of those times a mechanic has to t=rely on his/her native
handiness and/or experience.
To identify which of these parts is bad, locae the Trunk Release Relay (call your dealer parts
dept. for helpful tips on finding it), then operate the dashboard trunk release button with your
ear close tothe relay - if it makes a noise, the problem is the Trunk Lock Release Switch in
the trunk lid, otherwise its the relay.
Sam Akber
Level 3:
Genius:
  • Saturn Master 1,149 Answers
Sam Akber
Saturn Master
Level 3:
Genius:
Answers
1149
Questions
0
Helped
329910
Points
3323
Take the trunk switch out and power the switch.
Trunk won't open with either remote but will open with trunk button on drivers door
I would check the owners manual or with Cadillac - its possible the remotes lost part of the signal and need to be reset. It sounds like the receiver is not getting a signal from them by using that button.
Could be the receiver too.
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
1helpful
Trunk won't open
First, if it does need an actuator, you can save some money on labor getting it done at an idependent aftermarket shop rather than the dealer. Yes, the part will most likely have to come from the dealer, but let the shop deal with that. You do not have to pay dealership labor rates. It would pay to shop around.
Second, before any parts are purchaced, the actual CAUSE of the problem needs to be verified. Unfortunately, the ONLY way to do that is to get the trunk lid open and inspect the trunk lid latch components. If none of the three methods provided by the manufacturer for opening the trunk in a normal fashion will work, the trunk will have to be accessed by removing the back seat. Once the back seat is removed, a technician can reach into the trunk and remove the bolts that secure the trunk latch to get the trunk open. The latch parts can then be accessed to disassemble, inspect, and repair accordingly.
Please note that this is the ONLY way to do this without causing further damage to the vehicle. DO NOT allow anyone to attempt getting into the trunk any other way! (Do not use pry bars or screwdrivers on the trunk lid, key tumblers, etc..)
2answers
1helpful
My trunk won't open on my Lexus es350 with the
Checked the glove side button, tried to press all the buttons still won't work. What could be the possible problem that the truck won't open? There is no manual key way to open the trunk which now sounds ridiculous!! Please help!!
1helpful
'91 LS400, trunk will not open. key will not turn, electric latch switch clicks but won't open. valet lock in open position. Tried 1) disconnect battery, reconnect battery, use switch, push down on...
If you hear the sound of the electric latch switch, then it's working but stuck somehow. Just put the key in the switch and turn it to the right and then pull up the trunk or ask someone to help you. it will open. I tried it today and it opened with me. It was stuck from inside by some kind of a broken plastic pieces. Just removed it and now it's working fine. good luck
I have a Jaguar X300 3,2 '96 model with a jammed boot lock. On the instrumentpanel in the dashboard it indicates that the tailgate is open. I've tried to open with the button on the tailgate and...
the wiring around the trunk/boot hinge may be broken/opencircuit. the security system thnks the trunk/boot is open use the manual key to get in to the trunk and repair the wiring
2answers
The cable for the remote in the trunk came loose, now the trunk won't open with either the key or the button on the door. what to do?
You should be able to go in through the back seat. It will be a chore to remove the seat, but will probably be the only way to get in there. There is a safety release cable in the trunk that will opne it the lid for you once you get inside
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
