My Lanier P-165 is not operating properly. I think the gears are slipping or do not engage properly. I will be recording and all of a sudden it will stop, or it will not engage to record at all. I think if a technician looks at it, he can get it to operate properly, but not being sure, I thought I would ask you.
thee are gear cable adjustment that ensure complete engagement of the drive dog in the leg
If it properly adjusted then you will have to pull te leg off and dissemble the gear box and fit new gears and a dog clutch
because it is a straight engagement into square segments and the engine shaft is running it hits and misses until it eventually engages
over time instead of square segments they become tapered and so will slip back out of gear under load
the operator will normally be at fault as the engagement should be at low idle with a sharp movement of the selector lever
If you want to record somebody 3-4 feet from you then use the dictate mode. If you want to pick up voices in a large room then use the conference mode, it increases the microphone sensitivity to the maximum level.
I havent found one,but it appears simple enough to operate.Martel doesnt sell this unit anymore and i havent seen any I Manuals on the web.Looks like a quality unit though
Basically, your transmission is shot. There is no quick or easy fix for this, it will require at best a strip down and component replacement or at worst full rebuild or replacement. It sounds like it is slipping quite badly, and the slapping sound is it trying to put itself into gear.
gears slipping out of mesh indicates
1 ---not properly engaged on selection
2--- failing output shaft bearings
3-- worm slip joint bush in the extension housing not maintaining alignment of the output shaft
The gear engagement is by dog teeth in the synchro ring for 5th gear and if that connection alignment is not maintained exactly by bearings and bushes the dog teeth move out of engagement at each revolution
AS reverse gear operates through a moveable spur cut gear to engage the counter shaft and the out put shaft and you are having trouble with reverse as well , indicates the out put shaft rear bearing is suspect or is moving in the box housing
The Lanier P-165 has a slide switch on the side for master power off / on. Also the battery contacts get flattened over time, a letter opener can help you get these sprung back out to make contact with the battery. Anything more than that consider it toast, serious professional tape units havnt been made in 4 years now. Its all digital now.
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
yes I have two lanier voice recorders one left hand and one right hand one power supply real cheap do not use them any more . listed on ebay as lanier vw-110 standard cassette dictator. If you still need them. Thank you John
