Question about Korg D888 8 Track Recorder
When my Korg d8 power is on 'working' message is followed by Init>?, I cannot go beyond this. How to solve this problem? And can I change the internal Hard drive.
  • Korg Master
  • 5,603 Answers
It is asking for confirmation that you want to initialize the unit. The manual doesn't say anything about this... but you should try pressing the "Yes" button to confirm you want to initiallize the unit or press no if you want to staart without initializing.
Posted on Aug 16, 2011
SOURCE:
My korg N364 is out of tune. how do i fix it?
hello sir,
THIS IS SOFT RESET; FACTORY MUTE PARAMETERS WILL BE LOADED INTO ... ART, MULTIVERB LTX, No factory reset, remove battery for more than 5 hours. .... KORG, N364, HOLD ENTER AND 7, THEN POWER ON. KORG .... ROLAND, D-550, TUNE/FUNCTION AND MIDI DATA INIT: HOLD PATCH BANK 2,
thanks from: SHAAD GONDEKAR
Feb 21, 2017 | Korg Music
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
Cannot format or reload factory presets after it stopped working
The card that you used to transfer the files HAS to be (1) FORMATTED by the ESX-1 unit FIRST, (2) then put the card into your computer's card reader and download the files. (3) Put the card BACK into the ESX-1 and try reloading the factory presets. Good luck!
Jan 11, 2013 | Korg ESX1 Electribe SX production station...
Korg em-1 won't power on
Open it up and check the solder joints of the 9V DC input jack. Also, download the service manual here http://www.korg.com/SupportPage.aspx?productid=496
If you can't pinpoint the problem from the method given by Korg, then most likely the internal memory was erased somehow. This is the problem I have with my EM-1 and if anyone has a solution please share.
Sep 14, 2012 | Music
Korg d8 owners manual
Please check this link below and request for the manual to be downloaded.
http://www.korg.com/support
Dec 23, 2011 | Music
Hi, I have a korg D8 recorder and that i use pretty regularly.One day i switched it on and it was completely dead - no lights, nothing. I've tested the power supply (the one it was supplied with ) and...
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Jul 16, 2011 | Korg D888 8 Track Recorder
Hi i got the korg pa50sd when i swith it on it shows me korg pa50sd boot loading files then this goes off, still the light on display is on but blank display with nothing on it ,. i was trying to find any...
NOT a fuse... thaat person knows nothing. There is something wrong for sure. Check if one of the buttons or keys MIGHT be stuck down (depressed). Sometimes the units check that all the control buttons are up and they don't really tell you why they fail to start. Beyond this a repair shop is in order.
Jul 11, 2011 | Korg PA50SD Pro 61 Key Keyboard Bundle
I have a old (but almost unused) Korg d1200 recorder. Recently started getting disc error messages. Followed manual instructions to check disc drive and still get same results. Powered it up just now to...
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Jun 17, 2011 | Korg D888 8 Track Recorder
Korg D888 8 Track Recorder Logo
359 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
