Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Troubleshoot on following link:
http://waterheatertimer.org/Water-heater-is-tripping-breaker.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
HEATER,IMMERSION:
DIAMETER:
520 MM;
LENGTH:
1 M AND 520 MM;
VOLTAGE:
220 VAC;
WATTAGE:
STANDARD/SPECIFICATION:
MIL-H-10249B;
ADDITIONAL DATA:
ITEM ADDITIONAL DESCRIPTION:
WATER, 1 PH 50 60 HZ, 50 TO 55 GALLONS
CAPACITY, 3 4 INCH NPT CONNECTION;
ACCESSORIES:
WITH TEMPERATURE AND PRESSURE RELIEF VA
LVE.
A. O. SMITH CORP/ELECTRIC MOTOR DIV:
EES-52-913
EES-52
EES-52D
ECT-55
ECT-55-200
RHEEM MFG CO/RHEEM INTERNATIONAL DIV:
81MV52D
ECT-52
qty-08
HEATER,IMMERSION:
DIAMETER:
610 MM;
LENGTH:
1540 MM;
VOLTAGE:
240 VAC;
WATTAGE:
AMPERAGE:
11 TO 13 A;
MIL-H-10249B;
ADDITIONAL DATA:
WATER, 1 P 60 HZ, 80 GALLONS CAPACITY,
77 DEG C MAXIMUM TEMPERATURE SETTING, 8
BAR MAXIMUM WORKING PRESSURE
ACCESSORIES:
LVE, 3 4 INCH NPT CONNECTION.
A. O. SMITH CORP/CONSUMER PROD:
Model#EES-80
Model#81V80D
Model#EES-80D
qty-08
