Hello
You can use 75Ohms impedece co-axial cable to extent the antenna connection. Make sure to use a very well shelded cable. Use Moster brand if available. OK.
To extend the antenna of your Jlu 121Potter, you need coax cable. You can follow the general system diagram which is in the manual to attach the extended antenna.
You can also follow "http://www.c-trak.net/ctrak/Downloads/JRC/GPS_Plotters/JLU-121/JLU-121b.pdf". for more information.
Hope this will help you. Good Luck.
i know its a coax i whant to know what type eg 50 ohm rg59
what type of coax,there was nothing in the downloads
