don't have any speakers or electrical goods near t.v . now pure green circle in middle outer blue...i have a tv full of the hulks relatives !!!! don't have any speakers or electrical goods near t.v . now pure green circle in middle outer blue...i have a tv full of the hulks relatives !!!!
You can't post conmments that contain an email address.
If you wish to get some details; visit the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are almost similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts/
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sounds like T'Con board fault.
Faults due to T'Con board are shown wih illustrations.
Sounds like t'Con board fault. Contact any service technician to make it confirm.
Line, screen faults & possible causes to LCD screen are given with illustrations.
Vertical scan output circuit problem. Check all the components related to this section. Check all the solder terminals for any loose connection, to the vertical scan output IC.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Hello, let's make sure this is actually a problem with your TV, sometimes this can be a problem with a Cable box, if you're using one. Do you have the same problem with DVDs or a game console?
