These directions also work for Sony DAV-IS10
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changesHi I am unable to program my COMCAST remote to - icon1.pngmg src="/uploads/images/icon1.png" alt="icon1.png" class="h_mi" /> you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
SOURCE: Code for Comcast remote for Sony DAVHDX275
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
SOURCE: need a universal remote control code for sony dav-dz 100
1903 will work for most functions, but not the DVD player buttons.
SOURCE: Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
SOURCE: Cannot find code for Comcast remote to operate DVD
hi im having the same issue, have u managed to find an answer? [email protected]
SOURCE: program code for sony home theater DAV-DX250
my home theater model dav dz270 but my remoteis missing please help me what is the remote number
