Hello-
problem with sharp microwave kb-6014LS
boiling water in microwave caused microwave to stop. maybe steam caused a short circuit? seems like water "exploded" just before microwave shut down. it has no power now.
Is there a fuse I can check?
Thanks,
John
The new oven is providing more heat to your food, causing more water to boil out of it by the time it is done. It may be OK to shorten your cooking times in response to the higher power efficiency if it bothers you. Then again, maybe you bought a microwave steam oven. They're cool.
It is the control board that needs to be replaced. The LCD display is connected to the board. If this is an above the stove microwave the problem was caused by the steam from boiling water on the stove top. you can prevent it from happening again by using the vent fan consistantly.
I would guess that the boiling water may not have been the cause ...
If you are lucky ... try this first:
Unplug or turn the circuit breaker off (if it is a built in unit). Wait an hour and then repower.
Odds are that will not clear things up ... but it is easy to try. Probably one of the electronic internals broke.
A number of different internal component problems could cause this heating failure in the microwave. It could be the magnetron, the high voltage transformer, the PC board, the diode, and the capacitor. This type of problem will need to be diagnosed and repaired by a service technician. Microwaves are inherently dangerous to service. This type of repair is not something that you want to try to do yourself. Internal capacitors in the microwave can retain a lethal electrical charge even when the microwave is completely unplugged. A microwave radiation leakage test should be performed on the unit using proper testing equipment following any internal component repair.
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
did it come with the exhaust fan under it? if so just turn it on when boiling water if it didn't try to find one that goes with the unit and hve it installed, this is theonly way to fix the problem
I would say the transformer for the power supply has probably shorted, or another major component in the power supply has shorted - This may be repairable if easily spotted, but most likely will not be cost efective.
It's possible that the vents got blocked. If it vents to the outside, look for debris in the vent exit at the side or attic of the home.
If you're lucky, these will dry put (sometimes it helps to remove the cover) but sometimes the excess moisture gets in and cannot get out. This causes a keypad or control board failure.
Please post an update if you still need help.
