SOURCE: Fault code F5
Hi Marcos
Happy to help you!
But I see that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
SOURCE: how to get grease stains off
Hi, Is this a glass top type? If it is then DO NOT use any abrasives, soft scrub, ect. Use a razor scraper like for paint and keep it flat. Then purchase any commercial glass/ceramic cook top cleaner (grocery or hardware or diy store) and use a drop about the size of a dime on each burner. Fold a couple of paper towels and in a circular motion buff the top and when it looks clean turn the towels over on to the dry side and polish it to like new. Good Luck!
SOURCE: black enamel stove top,frigidaire
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
SOURCE: How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
SOURCE: none of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
