SOURCE: Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact can you hear it click?If its not clicking or the arm is broken off the lid replace the lid switch/or the broken lid switch arm.
SOURCE: Maytag PAV2300AWW Washer leaks while filling
Hello
Welcome to Fixya
My name is Huum,
Why did you change the hoses with old ones?
If you are going to change them use new ones!
Sounds like the drain hose connection to the washer is not tight or not secured, or not fitting th connection because it is from a different washing machine.
Or there is a hole in the inner tub and leaking out on the floor.
Do you know the ones that sold it to you?
Thank You For trusting us with your question
Please remember to leave a rating before you leave!
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
is your drain hose at the top of the washer .is the water just runing out is it being pump out
SOURCE: maytag neptne fav 6800 aww does not fill wiht hot water. works fi
Hi Big Wags
I would remove both water hoses at the back of the washer and check the Hot & Cold inlet screens for a clog/restriction.
They look like this;
You can turn the individual valves on in service mode using the procedure on page 16 of the Service Manual.
To enter Service Mode; press and hold simultaneously the Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.
Now go into board output test by pressing the Delicates key.
Now press the Normal button to open the Hot Water Valve you can press the Normal button again to turn off the valve or just press the Off button to end the process. Or just use the wash cycle to toggle the H/C water valves on. I like folks to become familiar with using Service Mode and the SM.
If the inlet screens are free of debris and you have good water pressure from your source valve then you may have to replace the valve assembly Here is a link to check for FAV6800AW PARTS Sears Parts Direct. Shout back If you have questions. Rich
