Since nothing worked for my phone (USB file transfer etc.), I tried to transfer files via a Bluetooth adapter. It found the phone, seemed to connect and it says that both devices are working properly, however when I tried to transfer the first photo connection dropped, and it does so every time I try to send files to my laptop. Can anyone help, what to do, this is really too much... :(
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
You will need to use a USB Bluetooth adapter on your computer in order to transfer files between a phone and computer via Bluetooth. Click here for an example.
In case there is no USB port, you may use the bluetooth dongle on your computer to transfer the files or you can also use a memory ard reader and insert your memory card in it, connect it to your computer and transfer the files.
As far as I know, you cannot transfer files to and from the memory card via bluetooth.
What I recommend is to either get a memory card reader for the memory card and insert it into your PC and transfer directly, or purchase the USB cable. It is worth the cost, since transfer speeds via bluetooth is pathetically slow.
Otherwise, you can transfer the files to your phone, then turn it on and move it to your memory card ofcourse. That way, you can avoid getting either the USB cable or memory card reader, but this means that you can only transfer 8mb at a time and is quite laboursome.
Have you installed the program that came with the phone? You have to install the mobile and PC sync program so that you can put songs on your phone. Go into the LG Phone Manager and plug in your phone by USB. Click on "Transfer" and then "Connect" to connect the phone to the computer. Then click on "Contents" on the left side of the screen and drag in the music files into the right folder.
I hope that this has helped. :)
i suggest you dont put in the music through ur computer but through bluetooth . if you have a mac that would be a good way as the macbook hav bluetooth . i have a KE970 but it wont start it restart automatically over and over again . i think the problem is because of a virus i got while downloading imgaes from the net . so make sure you check if you got viru's on the song .
