HTC Desire Cell Phone Logo
Posted on Sep 19, 2017
My HTC Desire S keeps freezing in about a minute after i have turned it on. And the only way to turn it off again, is to take out the battery. Now i can't even turn it on, now it just keep showing the HTC logo, vibrating, and getting black screen, show the HTC logo, vibrating and getting black screen, and it keeps do that like 6 times, then its just turned of
5 Related Answers
Anonymous
  • 21 Answers
  • Posted on Aug 19, 2010
SOURCE: when i turn on my htc desire it gets past the htc
there must be an application creating that prob. most probably a third party software u have installed. u have to hard reset ur cell phone. consult user guide of ur cell for instructions
Anonymous
  • 21 Answers
SOURCE: i have a htc desire
Anonymous
  • 70 Answers
  • Posted on Aug 26, 2010
SOURCE: on the first start up of my htc desire it
your phone have screen problem. you must change your screen or any hardware parts. pls chek your phone in htc's company shope.
Testimonial: "thiught as much onmy side and appreciate the conf"
Anonymous
  • 231 Answers
  • Posted on Sep 30, 2010
SOURCE: my htc desire keeps freezing. i cant unlock or
hey hi....
this is the problem usually caused by virus and sometimes it might be software failure also, which causes some of the menu not tofunction,the only solution is to flash ur phone software from the nearest HTC serice centre,it also updates your mobile software which increases the mobile speed....
thank you.....take care................
Anonymous
  • 145 Answers
  • Posted on May 14, 2011
SOURCE: HI my HTC desire keeps
its the fault in the restart integrated circuit its gets stuck when it gets heated,better replace it
My htc desire s keeps turning itself off. it only stays on if ts plugged into a charger. is is it te battery? If it is, is it worth getting a new battery for it?
HTC is a good phone, yes its the battery and its a nice enough phone to buy a new battery for it. its up to you.
Htc desire s blue screen freezing
Remove and Replace the Battery and that will reset it
Htc desire does not start
remove battery for 10-15 seconds and then try again.
My htc desire hd keeps freezing
This may be due to some apps crashing or waiting for response. Goto Taskmanager and observe which process is consuming your RAM. Uninstall that may fix it.
My HTC keeps freezing and then shuts off and it won't turn .. I have to plug it in my charger and I'm about five minutes it turns on
I would delete any live widgits off your desktops such as facebook or myspace etc. It constantly drains the battery and working with phones I have had it actually drain the battery faster than it can charge. If the charge is not the problem I would, while the phone is turned on, remove the battery...this is a soft reset and can fix most issues with freezing.
4helpful
My htc desire keeps freezing. i cant unlock or answer calls. have to take battery out and restart. even this does not work all of the time! help
hey hi....
6helpful
2answers
G1 keeps turning off by itself
g1 keep cutting off when im using the phone and turns it on and it cut back off and after charge phone it work right for a minute and turn back off
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
