SOURCE: Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
SOURCE: canon mp-730 print head does not move
it seems you open or unscrew the printer.
this may happen if the mother board has no nigative pole.
you have to reset the mother borad.
cannot do that from the available options
the reseting procedure is to take the motherboard out and you have to shortcut the battary for 10 seconds.
re install it , and try it
SOURCE: Problem with Canon MultiPASS F80
Try re-setting:
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
SOURCE: Check Printer Press Resume
I had also this problem try all stuff did not find anything ended up took the head out cleaned it using rubbing alcahol put it back after it asked for alignment ect of head and now its working
