Garden Logo
Posted on Aug 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have scott drop spreader and I want how it will setting for fertilizer
Anonymous
Level 2:
Novelist:
Champion:
  • Expert 214 Answers
  • Posted on Aug 14, 2011
Anonymous
Expert
Level 2:
Novelist:
Champion:
Answers
214
Questions
0
Helped
32291
Points
449
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Dec 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
9327
Points
16
Howdy Shan,
Most spreaders will use a 3-6 setting depending on the size of the granule and the type of spreader you have . You need to take into consideration your walking pace as well because over fertilizing will damage your grass.
Happy Gardening,Coach Dave
3 Related Answers
Anonymous
  • Posted on Mar 16, 2009
SOURCE: I have a Scott Rotary Fertilizer Spreader. When I
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
Anonymous
  • Posted on Jun 11, 2009
SOURCE: Need a quick way to convert Scott's settings to Earthway setting
add 10 - scotts turfbuilder spread at 4 on a scotts spreader should be on setting # 14 on an earthway spreader. happy yardening !
Anonymous
  • Posted on Mar 21, 2010
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
1helpful
What setting do i use for scotts Basic spreader?
Depends on the fertilizer you are going to use. There should be a table on the fertilizer bag showing the spreader and setting. If your spreader is not shown, select a spreader like yours for a setting. Watch how much coverage you get and adjust from there.
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
How do you know that the Classic Drop Spreader is adjusted properly? i'm using too much fertilizer in comparison to my old Scotts drop spreader and leaving too many burn marks. I thought that the...
I'm sorry to hear about the problems you are experiencing with your spreader. You're right, this is the correct way to adjust the calibration of the Classic Drop Spreader. If you are still having problems, you can call Scotts at 877-465-5160, and we can assist you further.
Hilary @ Scotts
I just bought a new Scott's "Classic Drop" Spreader. I owned a Scott's drop spreader before and the recommended settings on Scott's fertilizer bags always worked great. On...
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
The handle that should release the fertilizer, does not work.
With the bucket empty and the handle pulled open are ther holes in the botom of the bucketif not its jammed shut just needs cleaning with wd40
12helpful
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Settings for scotts products
The bag of fertilizer should tell you on the back of the setting for your spreader. It will say, Scotts 3000, Greenway XXX, etc, with the setting for that particular product.
3helpful
Need to apply lawn fertilizer at a rate of 5 lbs, per 1000 sqare feet, what setting do i need on my scott's speedygreen 3000 broadcast spreader.
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Scotts 3000 spreader needs calibration?
I found the manual that came with the spreader.. recalibrated it and it works fine.
Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Top Scotts Company Garden Experts
Jay Finke
Jay Finke
john h
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
