Power locks don't work with remote or control from
The door lock/unlock
input from the driver's key switch goes to the Door Multiplex control
unit (main switch), the Door multiplex control unit then sends a signal
on the BUS (CAN) circuit to the passenger's multiplex control unit; the
passenger's multiplex control unit then controls all the door locks. The passenger's door lock key switch inputs to the passenger's multiplex control unit, if the
locks work from the passenger's side key switch but not the driver's
side key switch, the most likely cause is the driver's multiplex
control unit (main switch) not sending the signal to the passenger's
side multiplex control unit. This could also be the drivers side door lock actuator. Hope this helps!
I after you take the clip off what do you do? I removed the clip but it still will not come out of the bracket.
2003 Honda my door lock on the drivers side now won't do anything lock or unlock with my key. Also the chrome came off my door handles in the front and almost cut your hands.
I have the door apart down to removingthe lock cyl., but I cant identify any retaining clip that holds it in
