Coleman 10' X 10' Sundome Tent 9160K101 Logo
Posted on Aug 14, 2011
My 4345 led rechargeable lantern is not working please help
Issue with Coleman 4345 rechargeable lamp.
It sounds like the internal battery is faulty. Have you tested the time the light will stay on at low setting against what the advertising says 66 hours? The Cree Light module has a current sensor in it and will cut off when there isn't enough current.
https://www.google.com/search?q=Coleman+4345+rechargeable+lamp
This says it takes 8 D-Size batteries, and doesn't mention rechargeable at all?
Coleman 8D Family Size LED Lantern - 4345-701
Size: 7.28'' x 11.81'' (18.49 cm x 30 cm)
  • Cree XLamp XR-E LED 175 lumens on high
  • Run time: 66 hours on low, 32 hours on high
  • Four-position switch - Off/High/Low/Nightlight settings
  • Durable chrome-plated rhino guard
  • Cool touch LED keeps lantern cool while running
  • Weather resistant to withstand the elements
  • Weighs 3.26 (1.48 kg) without batteries
  • Operates: 8D batteries, not included
Camping Station https://www.campingstation.com > coleman-led-lantern-4...
Coleman 8D Family Size LED Lantern - 4345-701. Size: 7.28'' x 11.81'' (18.49 cm x 30 cm). Cree XLamp XR-E LED 175 lumens on high; Run time: 66 hours on low, ...
US$46.99
Or this one 4345-702 which runs on 4 D-Cell batteries.
https://www.ebay.com/itm/314067312209
Toyota Van. How to cut into wiring of the rear roof lights to connect to camper leisure battery without removing the roof lining?
Pretty much impossible unless you fish it through with a snake wire. You don't say why you are trying to do this? Just use a standalone rechargeable LED light or lantern.
The 8 Best Rechargeable Lanterns For Camping (Keep ...
Beyond The Tent https://www.beyondthetent.com > Camping Gear
Aug 19, 2020 - Nite Ize Radiant 314 ... The Nite Ize 314 is a workhorse of a rechargeable lantern that gives you everything you need at a reasonable price. It ...
Best Camping Lanterns of 2023
Switchback Travel https://www.switchbacktravel.com > best-camping-lant...
Jul 19, 2023 - LE LED Camping Lantern ($27). LE LED camping lantern ... What we like: Decent brightness and a rechargeable battery in a light and streamlined ...
1helpful
Ozark Trail CL-108-2 LED Rechargeable Lantern. I have a rechargeable lantern. Need replacement everything!
Question edited for clarity, FULL 'make model (what it is)'.
These are cheap junk made in China. There is no support and no spares. Buy a new one on Amazon, there are two left and use yours for spares. if you need them. Read these reviews!
https://www.trailspace.com/gear/ozark-trail/led-rechargeable-lantern/
https://www.google.com/search?q=Ozark+Trail+CL-108-2
It you want quality and support, buy Fenix, O-Light or Petzl
Nepo Redline Blast RC Rechargeable Waterproof Flashlight. Where can I get the circuit board for it please.
Question edited for clarity, full 'make model (what it is)'. 'Waisted', the area around a female's middle. 'Wasted', wrecked.
Question moved from Television and Video.
Go direct to the maker for a warranty repair.
Contact nebo
https://nebo.acgbrands.com > en_US > contact
Contact nebo. How can we help you? Questions / Comments. Questions / Comments Warranty Claim Warranty Registration Return Track Order ...
Need to change battery in my 4345 lantern
If you are talking about the Coleman 4345 lantern it is rechargeable using one of the chargers (mains or car) stored in the base. Are you saying it won't recharge?
2helpful
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 • Dryers
Top Coleman Sport & Outdoor - Others Experts
Kardoc
vince
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
