Hi, The problem is most likely the clutch solenoid not releasing the clutch which allows the bowl to spin with the agitator. This can also be noted in the wash cycle where the bowl will move in small increments at times during the wash. This fault may be caused by a failed triac on the control board, a failed clutch release motor or an open circuit wire to the motor.
This problem relates to your lid switch most likely. Try depressing the switch with a pen or small screwdriver while the machine is on but stopped and see if it takes off, if so you just need to adjust it so it makes contack. If your hearing it click but the machine still won't spin then the switch is most likely bad, you can however twist the wires together ont eh switch to see if it is the problem but you will be left without the safet device to keep someone from getting hurt when the machine is spinning. I assume it is pumping out ok otherwise, a blocked pump can also cause this or a bad pressure switch but lets concentrate on the lid switch first. Let me know how this is working for you.
