With any device, it is helpful to know the brand and model number. I will provide a few links to some cotton candy maker's repairs but you have left out the crucial information. Not to worry. You can google "cotton candy maker" the brand and repair and possibly find some information. Even better, you don't have to have the machine to make cotton candy. I will provide links to that as well.
Here is how to operate a professional cotton candy machine.
First of all make sure you are renting the machine from a reputable company and that it arrives with a trained professional who knows how to operate it properly.
Also make sure that the machine is on a steady base and that no children or animals can get too close.
It is best to use a plug just for the machine instead of sharing it with other appliances.
To begin, turn on the machine's main power switch and fill the floss head with sugar.
It is very important not to fill the head above 90%.
Turn the machine's motor and then the heat switch on, putting the head dial setting on HIGH.
The sugar will start forming in about 45-60 seconds.
When the cotton candy starts pouring out you should have your cone ready. Dip it in the machine and pick the cotton candy by giving the cone a twirl that will gather the sugar around the cone.
Avoid rolling the cone around in circles as it is not the correct method to gather cotton candy.
When you are done, first of all turn off the HEAT and allow the motor to continue running at least 45 seconds, in order to get rid of the leftover sugar, and cool down the heating element.
Than disconnect the stabilizer screen and clips, rinsing them in warm water to dissolve the sugar.
You can now remove the floss pan from the main unit and rinse it off.
Children must not play with the cotton candy machine. It certainly is fun but it is not a toy.
If your Crazart cotton candy maker is no longer producing cotton candy, there could be a few potential issues to consider. Here are some steps you can take to troubleshoot the problem:
Check the power supply: Make sure that the machine is properly plugged in and that the outlet is functioning properly. You may also want to check the fuse or circuit breaker to ensure that the machine is getting the proper power supply.
Check the heating element: If the heating element on the machine is not functioning properly, it may be preventing the machine from producing cotton candy. You may need to replace the heating element to fix the issue.
Check the spinning head: If the spinning head on the machine is not functioning properly, it may not be able to spin the sugar into cotton candy. You may need to replace the spinning head to fix the issue.
Check the floss bucket: If the floss bucket on the machine is not properly seated or is damaged, it may be preventing the machine from producing cotton candy. Make sure that the floss bucket is properly seated and check for any visible damage.
If none of these steps resolve the issue, it is possible that there is a deeper malfunction or defect with the machine that will need to be addressed by a professional. In this case, you may want to consider contacting the manufacturer or a customer service representative for further assistance.
I believe you are looking for the Manual for the Nostalgia Electrics PCM805 Hard & Sugar Free Cotton Candy Maker which can be found online here: http://nostalgiaelectrics.com/manuals/PCM805.pdf
