SOURCE: de-scaling
Try doing descaling with a descaling product , like the ones below:
Urnex Cleancaf Coffee Maker Espresso Machine ...
$9.99 - DBROTH
Miele Coffee Machine & Steam Oven Descaling ...
$20.55 - Totalvac.com
SOURCE: Keurig machine releasing coffee grounds on top of K cups
I have the same problem but if you take a paper towel and clean the grounds from the top each time it helps. Cleaning around the little point that pierces the cup. It helps but doesn't completely eliminate the problem.
SOURCE: Keurig troubles
I started to have the same problem. I think I solved it, at least it is running better now. I opened up the lid, where the cup goes and removed the bottom insert, where the cup sits. It looked a little scaled at the bottom despite my earlier cleaning attempts with vinegar and such. So I just used a toothpick to rub the edges of the holes where the coffee exits to the cup, then cleaned in hot soapy water. It just made a good full cup, much more than it had been doing. Hope this helps . . .
SOURCE: my keurig coffee maker is making really watered
I have no idea what this is but perhaps the water spout is out of alignment with the filter and missing the coffee. Check for small blockages that could be misdirecting the flow of water.
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day. I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
