Yes, you can operate the fridge on propane while driving, instead of running the generator for electric operation. However, you should have a dual tank setup to prevent running out of propane.
Propane tanks with OPD valves aren't holding a true 20 lbs of LP, but rather only hold 17-18 lbs of LP. However, if you're swapping/exchanging your tanks instead of having them refilled, you're only getting 15 lbs of LP in the tanks these days, (check the label at the bottom of the tank to confirm). Hence the reason to have a dual tank setup on your RV to get longer run times.
I thought you might want to have a tech manual for your fridge, so here's a link to the Dometic site, you just need to select yours based on the manufacture date, etc.
http://www.dometicmanuals.com/UM/Dometic/MASTERDometic.nsf?Opendatabase
Hope you find this Very Helpful and best regards!
