SOURCE: Laptop won't startup
just push "num lock" button :).
This flashing Lock symbol [9] means "Num Lock" is on - numeric keyboard enabled. If you wish turn it on or off just press the <Num lock> key, sometimes you have to use the <FN>+<Num Lock> keys.
SOURCE: Vostro 1510
Possible memory issue. Try Reseating your memory card on the system, it would be helpful.
SOURCE: Dell Latitude D610 won't start. Caps Lock flashes a few times.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&cs=28&l=en&s=dfb&journalid=656DBBED5AFCEABBE040AE0AB8E17A47&treeid=084A4C3E0A9C9EEEE0401E0A55172321&Query=bm8rcG9zdA==&SystemID=LAT_PNT_PM_D610&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
Follow Each and Every Step. To get Exact Resolution.
Hope this help. Please
Rate My Response! Thanks!
PREM
SOURCE: on boot up a lock symbol with a '9' is lit & nothing else happens
the "9" inside a lock means that your Num Lock button has been pressed. If all you see is the ">" then maybe you are looking at what's called a DOS prompt, and I have no idea why that would display. Try holding the Power Switch for 10 seconds and restart your computer. Hopefully things will be better, and you know where your Num Lock key is.
