That should just be a buffer. Give the video enough time to load from the source. Generally, there are two lines at the bottom on the playback bar, in the same space. Like, on YouTube for instance, there is the red line that shows how much you've watched, and a grey line that shows how much of the video is loaded. If not enough of the video has loaded, and the red bar catches up to the grey, it will buffer and show the circular moving dots.
Hi, Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty. Put video head cleaning tape and playback it as per instructions. hope this will help you. Thanks.
please state the age of your devices. It can help a great lot in solving your problems. The lines that you get aren't continuous, are they? They appear to be going up and down, are different sizes and shift as the tape plays, yes? well, this is simple. You need to clean your recording head.
The monitor you view while recording does not read from the tape where the problem is located, that's why you are not seeing them during recording.
Since they are not visible while recording, the video section is healthy, only the recording is faulty and it is unlikely you can do anything at home to correct it.
This may be a common problem and perhaps Canon is familiar with it.
I recommend you call their service line directly:
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
I have the same problem happening and can't find a straight answer. Some posts are leading me to believe that it may be dirty heads, and that the camera needs cleaning.
