The logic board of my seagate st3500418as was fried. can i buy and replace its logic board for me to recover the files inside that harddrive?..also, where can i buy that board? can i use a board with different firmware,p/n, datecode,and site code to replace the fried board? many thanks!
    Dedicated:
    Visited the website for 20 consecutive days.
  • 337 Answers
Https://www.seagate.com/consumer/
the above link will take you to the best support. Personally I might acquire the same model and swap out the hard drive but Seagate offers a wide variety of data recovery as well. Some drives came with warrantied data recovery
Posted on Feb 14, 2018
SOURCE:
  • 641 Answers
SOURCE: DU1100xtpt6
If you have "good hands" and a technical orientation, you can manage it by yourself (board and heating element). In any case, before buying a new heating element, check element's resistance with a multi-meter, maybe there is no problem with it. Be aware that before starting work on the machine, you should unplug its power cable !!!! In case you will need for an heating element, you can contact any washing machine spare parts store and by giving them your machine's details you will get it. Good luck!
Posted on Aug 14, 2007
SOURCE: Bad logic board on Western Digital Caviar SE16 500...
Are you still looking for the PCB?
Maybe I can help you to find it.
PM me on this forum http://forum.hddguru.com/hard-disk-drives-repair-and-data-recovery-f1/
Username: dav34
Posted on Jan 13, 2008
  • 432 Answers
SOURCE: harddrive is not detecting bios
get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
Posted on Apr 10, 2009
dlundmark
  • 797 Answers
SOURCE: not make instal xp
It seems you are saying that the board will not see the new hd.
You need the instructions for the hard drive and the mother board to install the SATA drive.
Some motherboards may need to have the bios upgraded, if it can.
Others are too old.
Posted on Sep 26, 2009
  • 12 Answers
SOURCE: seagate st3500320as firmware sd15 not recognize by bios
You need to access the drive controller and reset it using an RS232 to CMOS convertor and hyperterminal. The problem is caused by the firmware on the controller software going into an infinite loop.
If bios is not seeing it then none of the software tools available will allow access.
Once the hard drive is reset, the disk is fully useable again. A firmware upgrade is possible at this point, but usually we just image the disk and load it onto a more reliable replacement as most customers do not want to experience that sort of fright again.
I have fixed a few of these and have the equipment to do it, but it is not really a task for the amateur.
Posted on Nov 17, 2009
My 120 Gb seagate Sata harddisk got fired due to high voltage shock. What can i do. Is there any way i can reapair it. Is there any way i can replace the logic board of it with 80 Gb board and try.
I understand the value of the files that resides on the disk:) Yes! It is possible that harddisk may back to life by replacing the logic board but of the same model or part number. If it is not possible by replacing logic board due to other defects such as head crash and spindle drive motor opened/shorted, there still a big chance to recover depending how you value the data on it by contacting international Seagate Data Recovery support service with considerable service fee. Hope this helps.
Mar 04, 2014 | Seagate BARRACUDA Computers & Internet
External hard disk
As you are a seagate user so it would be advisable to try using this software to recover seagate sata hard drive. Just download it online for free trial.
May 22, 2012 | Seagate ST3500418AS 500GB 7200RPM SATA...
I burned out my external hard drives PCB board and I am unable to find a new one
The Printed Circuit Board ON THE Harddrive inside the Seagate FreeAgent, or the small PCB inside the Seagate FreeAgent's external enclosure? (Case)
If you are referring to the small PCB that the Harddrive connects to, and has the USB cable coming from it, just buy an external enclosure, and install the Harddrive into it.
http://www.youtube.com/watch?v=0HZ-wTdscgc
If your Seagate is like the one in the link above, it has a laptop size Harddrive in it, and it is a SATA unit.
2.5 inches across in width. (2 and a half inches)
This is an example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
IF you are referring to the PCB on the Harddrive itself, good luck.
One method would be to buy another harddrive like the one in the Seagate FreeAgent, and use it's PCB so that you can retrieve your information.
Then reinstall the PCB on the new harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 17, 2011 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
PC does not see the hard drive
Your hard drive is bad, seagate is known to have this faulty promblem, there are many user out there who face the same situation that you have. The only solution to this, is to replace a new external harddrive, or buy a hard disk and insalled it inside the harddrive enclosure. You might be able to still recover any data that was stored in your harddisk if you take it to bestbuy, office depot or a place that willing to do a disk file recovery. It is costyl however.
Feb 05, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hi, My Seagate 80GB IDE HDD is not detected in BIOS. But the drive is spinning. Is there any way I can recover my data?
If data in your hard drive is really important to you, try to look for a similar model hard drive. Then swap the logic board of the good hard drive with the defective hard drive. If the cause of problem is the logic board, then your hard drive should work by now. If you are not that technical, you can ask a technician to do this for you. You can buy a second hand hard disk for a few bucks at ebay.
Dec 28, 2010 | Seagate HD-ST380215A Barracuda 7200.10...
Hard disk failure... unable to start
FIRST PART OF PROBLEM, YES THE DATA MIGHT BE ABLE TO BE RECOVERED, BUT IT WILL TAKE SPECIAL SOFTWARE TO DO IT. YOU NEED TO FIND A REPAIR OUTLET THAT CAN RECOVER DATA ON A DAMAGED DRIVE. THEY CAN HANDLE THINGS LIKE THIS.
THE SECOND PART IS HARD TO READ BUT I WOULD SAY IF YOU ARE MIXING VOLTAGES ETC. YOU PROBABLY HAVE FRIED NUMEROUS THINGS. THIS IS NOT GOOD. FINDING A SECOND HAND BOARD IS VERY CHANCEY! YOU DON'T KNOW WHAT YOU ARE GETTING.THE DRIVE IS PROBABLY RUINED ALSO. YOU ARE LOOKING AT A MAJOR REPAIR, REBUILD. YOU NEED TO START TO GET EVERYTHING COMPATIBLE, SAME VOLTAGE ETC. DO NOT PLUG HARD DRIVES IN WITH POWER ON OR UNPLUG THEM WITH POWER ON. THAT WILL DESTROY THEM. THE DATA MIGHT BE RECOVEABLE ON THE ONE DRIVE, BUT IT WILL MIGHT HAVE TO BE SENT TO A SPECIAL LOCATION TO RECOVER THE DATA. THIS IS ALSO USUALLY FAIRLY EXPENSIVE SO BE PREPARED. HOPE THIS HELPS.
Nov 01, 2008 | Computers & Internet
Hard drive not spinning up
Hi you would have to buy a replacement drive that works that is the same as the one you zapped and change over the board to see if you did any other damage to the drive motor or send it to a recovery person which would probably be cheaper in the long run.
peter
Jul 13, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Seagate SATA 160 GB (ST3160827AS) fried!
Are the logic board model numbers the same? How about year and batch manufature? check on that.
Sep 20, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Open Questions:
Gmail Technical Support Phone Number # I:8OO-828-O294 .U.S.A This gmail USA phone number is ranked #2 out of 2 because 7,728 gmail USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the gmail USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, gmail USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. gmail USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact gmail USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling gmail USA Calling gmail USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from gmail USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with gmail USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare gmail USA's phone numbers against each other. Contacting gmail USA in General While I8OO8280294 is gmail USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach gmail USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact gmail USA.
Oct 16, 2019 | Best Computers & Internet
KODAK PRINTER Technical Support # I:8OO-8O3-IO69 Phone Number This KODAK PRINTER USA phone number is ranked #2 out of 2 because 7,728 KODAK PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O3IO69 is to reach the KODAK PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, KODAK PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KODAK PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO803IO69 and ways to call or contact KODAK PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KODAK PRINTER USA Calling KODAK PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KODAK PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KODAK PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KODAK PRINTER USA's phone numbers against each other. Contacting KODAK PRINTER USA in General While I8OO803IO69 is KODAK PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO803IO69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KODAK PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KODAK PRINTER USA.
Oct 16, 2019 | Kodak Computers & Internet
EPSON PRINTER Technical Support # I:8OO-8O3-IO69 Phone Number This EPSON PRINTER USA phone number is ranked #2 out of 2 because 7,728 EPSON PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O3IO69 is to reach the EPSON PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, EPSON PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. EPSON PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO803IO69 and ways to call or contact EPSON PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling EPSON PRINTER USA Calling EPSON PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from EPSON PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with EPSON PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare EPSON PRINTER USA's phone numbers against each other. Contacting EPSON PRINTER USA in General While I8OO803IO69 is EPSON PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO803IO69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach EPSON PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact EPSON PRINTER USA.
Oct 16, 2019 | Epson Computers & Internet
LEXMARK PRINTER Technical Support # I:8OO-8O3-IO69 Phone Number This LEXMARK PRINTER USA phone number is ranked #2 out of 2 because 7,728 LEXMARK PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O3IO69 is to reach the LEXMARK PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, LEXMARK PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. LEXMARK PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO803IO69 and ways to call or contact LEXMARK PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling LEXMARK PRINTER USA Calling LEXMARK PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from LEXMARK PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with LEXMARK PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare LEXMARK PRINTER USA's phone numbers against each other. Contacting LEXMARK PRINTER USA in General While I8OO803IO69 is LEXMARK PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO803IO69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach LEXMARK PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact LEXMARK PRINTER USA.
Oct 16, 2019 | Lexmark Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
