From user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
SOURCE: samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
SOURCE: SyncMaster 204B 20.1" LCD Monitor: how do you switch between digital to analog?...
Here is the user manual, read all about your monitor:
http://www.retrevo.com/support/Samsung-204B-Monitors-manual/id/278dj694/t/2/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: Have recently purchased a new
Here is a link to a cable on Amazon that will do what you want.
http://www.amazon.com/Cables-Unlimited-PCM-2296-06-HDMI-Cable/dp/B0007MWE1E/ref=sr_1_3?ie=UTF8&qid=1316748894&sr=8-3
I hope this helps, if so please rate my solution,
BuddyMc
