HTC G2 HTC Magic My Touch Crystal Phone Cover Case Butterfly (Tmobile Gsm) Logo
Anonymous Posted on Aug 13, 2011
How to acess my spell check when I'm text
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Aug 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
2439
Points
54
For android phone you can go to Android Keyboard setting on your phone that is usually where the spell check then you can change setting.
  • wluckyladies Sep 04, 2011
    I have the same problem with my HTC Merge. I can't find the spell check either. Would be nice to be able to get full hard copy manual to be able to find the questions we need.
Can you add the spell check feature to Facebook?
Facebook doesn't have it's own spell check. Google chrome does. Anytime you are in a text field (aka you are typing something on facebook or something ) right click in the text box and check out spell checker options.
I have an acer netbook and when i was in my word pad i couldn't find my spell check. How do i get that?
Hi!
Wordpad is a text editor coming toghether with Windows operating systems. They made it very simple, that's why it doesn't offer advanced features like spell checking.
Microsoft includes such features in Microsoft Office Word.
Best regards!
I cant acess facebook using my gmail account
You need to signup for facebook. Then if you had already signed up,but forgot your password, you can use 'Forgot password' so that password would be mailed to your gmail inbox. Also,if your emailid you type in login box might be having spelling mistake. Check it.
How do you type things and use spell cheack?
i will give you instructions
Instructions
  1. Select the text you want to spell check, or place the cursor anywhere in the text to spell check the entire document.
  2. Go to the Tools menu.
  3. Select Spelling and Grammar. The Spelling and Grammar window opens, and Word begins spell checking.
  4. View any flagged words or phrases in the upper-left window. Just above this window, you will see the reason Word has flagged this text.
  5. Check the Suggestions window in the lower-left corner of the Spelling and Grammar window for correction suggestions.
  6. Click the Change button to make the suggested correction.
  7. Click Change All if you want all instances of this error corrected within the text that you are spell checking.
  8. Enter your own change if you disagree with the suggested correction (or if there is no suggestion) by placing your cursor in the flagged text window and correcting the text as you would in any Word document.
  9. Click the Change button to implement your correction.
  10. Click Ignore if no correction is needed; click Ignore All to skip all further occurrences of this "misspelling."
How do i find spell check on printshop 2.0
If you will check the PS Help files, you'll see that those Help files say this about Spell Check:
To check the spelling in your whole project, make sure that none of the text boxes are selected. (Click anywhere off the edge of the project page.)
Tip: To check the spelling in only one text box, click that text box.
Choose Spell Check from the Tools menu.
If you have a misspelled word, the Check Spelling dialog box displays.
1helpful
There seems to be no help for changing font size on incoming e-mails and outgoing. They are way too small. Can't seem to get to font size on printer any moreto correct it. This problem came about when our...
Hi. It sounds like you may have accidentally set your browser text to a small number.
If you hold down the ctrl key, and scroll with your mouse wheel, it will enlarge your text.
Your question was a bit unclear however, so if this isn't the correct solution, please comment, and I'll try to help again.
33helpful
2answers
I want to turn off Predictive (spell) text - How?
Hello.
Welcome To Fixya Community.
I am glad To help You Sir.
"To activate/deactivate predictive text input, press # twice quickly.
This activates predictive text input for all editors in the
device."*
*Source:
Nokia E51 User Guide.
Thank You For Using Fixya.
Please Give a good Feedback^^
2answers
It wont spell or grammar check
Click the Office button at the top left and go to Word Options. Select Proofing, then hit the Recheck Document button.
Please rate this solution!
~~Cheryl
14helpful
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
