Sir the problem of your tv has two possibility, the inverter board may be damage or there is no supply to the inverter board. To check the voltage input on your inverter board you should remove the back cover of your tv, the supply input is 24 volts dc. If you can do this let me know.
Yes you can replace it by yourself. For the inverter board try to check this site http://www.shopjimmy.com/catalogsearch/r... just indicate the model of your tv. Feel free to send feed back.
First
connect the TV to a DVD player using a different cord. If there is
still no display, then it means fault is from your inverter board.
From the description of your symptoms, your inverter board has failed, a
way to verify this is when it goes black, in a dark or dim room, shine a
flashlight into the screen, and see if you see faint images in the
light. If so, the inverter has failed and needs to be replaced. The
inverter board is what controls the backlighting. A replacement inverter
board runs about $180, plus around $100 for labor. From the description
of your symptoms, your inverter board has failed, a way to verify this
is when it goes black, in a dark or dim room, shine a flashlight into
the screen, and see if you see faint images in the light. If so, the
inverter has failed and needs to be replaced. The inverter board is what
controls the backlighting. A replacement inverter board runs about
Keep me posted.
Regards
Where can I get a inverter board, and can I change it out myself
took back off tv
do you have a descrption or pic of the inverter
found one at shopjimmys, just want to confirm
will let you know what happens
