SOURCE: rio carbon upgrader message
Hi Linda, Your Rio Carbon is telling you that something is messed with its firmware and it can be resolved with an upgrade. You have to determine the exact model of your unit and download the firmware from http://www.digitalnetworksna.com/support/rio/. Again you must choose the exact model. There are two ways of updating firmware updater or internet updater. complete instructions are also available. further you would need to connect your Rio to a PC to perform the upgrade. Good luck and pls post back should you need further information. Kind regards.
SOURCE: Rio Carbon Stuck in Upgrader Mode
Hi Allyson,
This is a problem which I have encountered alot with my Rio Carbon.
A solution which always works for me is to hold the player face down in my left hand and then slap the back of it with my right palm a little harder than I would if I was winding a baby.
Best wishes, I hope this works for you as it does for me.
SOURCE: Rio Carbon
You will have broken the hard drive,
Try replacing it with a CF card,
Everybody says that this does not work but it definitely does!
My
Rio got dropped and I completely buggered the hard drive so after
reading many forums saying that it didn't work I read one that said
that someone had told them that sandisk ultra II ones worked (very
vague!)
Because I had nothing to lose I went out and bought a
1GB sandisk Ultra II CF card. I then took apart my rio and replaced the
hard drive with the CF card. Still not thinking it was going to work I
plugged it into my computer and installed the latest firmware (from the
rio website) and then HEY PRESTO!!!!!! it works.
I have yet to try an 8GB ultra II card but when I do i will keep you posted.
If you don't believe me then I don't blame you but If you send me a request then I can send you pictures and more details...
Rio will live on
Hope this helps
Mowcius
SOURCE: rio carbon is saying upgrader
u have to upgrade the firmwxare of ur unit u can perform that while downloading the utilty from the main support page .
SOURCE: Rio Carbon stuck on Formatting
Leave it for around 2 hours to format. If it is still formatting, pull the cable out. Some of your data may corrupt, but it will get unstuck. Then plug it in again, go to Start>My Computer, right click your player, and select format.
