Problem is not clear.
Is water heater clogged and not draining?
What kind of shut off is normally located down near drain valve on electric water heater?
If you have gas heater, you can normally just rotate knob to pilot to shut off burner.
If you are draining electric water heater, normally you turn off circuit breaker, attach garden hose to drain valve, open drain valve by turning counterclockwise, open TP valve or open bathtub faucet, and then water drains out.
Open following links for illustrations.
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
