WOW ! NO OS STATE AT ALL, is this the virus magnet XP?or Vista.
Circa 2005 , 12 long years old.... no spring chicken this... not at all.
most are in the land fill or sent to 3rd world as punishment...LOL.
best place to send is N.Korea this PC.
V5000 , ok that is first what is it.
WIFI yes, the pain of wifi, I use it as backup only, and only on CELL phones at home. we run gigalan at home and huge media server,
runs rock solid.
but wifi is a complex topic,not something that leads its self to text box, at all.
Router fine means other PC and cells all connect and work.
so its a PC issues. only only THIS PC.
but WAIT , (that comment on newer)
my guess is the router is wisely set to WPA1 /2 encrpytion (ONLY)
and then you bop in with a old Laptop hat is only WEP only or set to that only.
wep is not secure, so we dont use that TODAY. ever.
my wild guess, 2005 with XP right,?
the 3 years now dead OS, that HP nor MS support. at all
and known virus magnet, and over 700 exploits, (many not fixed)
facts, that.
for my next trick I will attempt to find what cards for wlan is there.
you never said, so will assume it's HP part, day one part.
not modified, as all can be.. see photo below for 1 matchup.
as you saw that XP wireless agent cant see your routers
broad cast, so that means , my guess is the your settings are wrong. or wrong driver loaded. (or bad card below)
if the router is set to WPA only and your agent (client app) is set to WEP
it can't see the WPA router. and for sure never connect .
why not look in your router first, see how its setup ?t.
mine is set to wpa+ (1 or 2)
but I could set it to accept WEP+WPA/1/2/ but id never do that.
ever,
i run wpa only. for security max.
so set your client to what you have your router set to.
it is that simple if drivers good. and XP not infected as ALL ARE.
this is what came new on it. (varies by exact model pc no t stated)
it does wep. and wpa
BCM94311mcgp , knowing what is there , IS EVERYTHING.
MY GUESS , WRONG XP DRIVER LOADED OR CORRuPUTED.
SOURCE: I want to use a second wifi router as an access point for my XBox
It might be better if you just get a 25-100 foot eathernet cable so you do not have to mess with a second wirless network system a may be a eathernet switch box.
SOURCE: router does not lock in chan 11 to have a constant
Is there a wireless phone near you? if there is, the router maybe changing its frequency for it not to have interference.
SOURCE: can`t conect to the wifi
Try resetting the router and then see if the WLAN will lit up.Maybe it just disabled on the router. have you tried accessing the router's setup page to see?
SOURCE: what do I need to make a wifi hot spot for my lap
In order to create an effective Wi-FI hotspot in your home or place of business you will need the following:
1.) A broadband internet connection, such as DSL or cable.
2.) A wireless router, Linksys makes a decent one but the brand is not really relevant for our purposes.
3.) Your laptop must have a wireless adapter on it. If it did not come with one, you can purchase one that will plug in to a USB port.
4.) That should do it, though configuring one can be tricky if you've never done it before. Post if you need some more help with it.
SOURCE: How can I setup my Linksys 54g v2.2, with my ZyXel 660r
First of all you need to set you modem router to bridge mode. go to this link will explaine in more detail
http://kb.earthlink.net/case.asp?articale=69205
remember to change the linksys router ip to 192.168.2.1 or 192.168.0.1 somthing different from the modem .
Hughes modems are all set to 192.168.0.1 so simply setting the linksys router to default 192.168.1.1
you need to change the linksys router IP to somthing different 192.168.0.1
