Sure, here's the user manual for the Panasonic air purifier with humidifier F-VXT70:
Introduction: Thank you for purchasing the Panasonic air purifier with humidifier F-VXT70. This unit combines a powerful air purifying function with a high-performance humidifying function to provide you with clean and comfortable air.
Safety precautions: Please read and follow all safety precautions before using this product.
This product is for indoor use only.
Do not use this product for any purpose other than its intended use.
Do not disassemble or modify this product.
Keep this product out of reach of children and pets.
Unplug this product before cleaning or maintaining it.
Do not use this product near water.
Do not use this product with a damaged power cord.
Do not use this product if it has been dropped or damaged.
Use only the power cord provided with this product.
Operating instructions:
Place the unit in a stable location near a power outlet.
Open the water tank cover and fill the tank with clean water up to the MAX line.
Close the water tank cover and plug in the power cord.
Press the power button to turn on the unit. The air purifying and humidifying functions will start automatically.
Use the mode button to select the desired mode:
Auto mode: The unit will automatically adjust its operation based on the air quality and humidity level.
Manual mode: You can adjust the fan speed and humidity level manually.
Use the fan speed button to adjust the fan speed in manual mode.
Use the humidity level button to adjust the humidity level in manual mode.
When the water in the tank runs out, the unit will automatically stop the humidifying function. You can refill the tank and resume operation by pressing the power button again.
Clean the unit regularly according to the maintenance instructions in the user manual.
Maintenance instructions:
Unplug the power cord and empty the water tank before cleaning the unit.
Use a soft cloth to wipe the exterior of the unit.
Remove the filter and wash it with water. Allow it to dry completely before reinstalling it.
Clean the water tank with a soft brush and mild detergent. Rinse thoroughly and allow it to dry completely before refilling it.
Clean the humidifying unit with a soft brush and mild detergent. Rinse thoroughly and allow it to dry completely before reinstalling it.
Reassemble the unit and plug in the power cord.
Troubleshooting: If the unit does not operate properly, try the following solutions:
Make sure the power cord is securely plugged into the power outlet.
Check the water tank and refill it if necessary.
Clean the filter, water tank, and humidifying unit according to the maintenance instructions.
Contact the customer service center if the problem persists.
The whole point of the % setting is so that the room holds at that %. When the humidity drops lower than, it will kick in. When it raises to that number it will turn off.
If the on and off is bugging you try raising the percentage. Or lower the temperature of your house. Heating will dry out the air and cause your machine to kick in.
Here is the link for the user manual for your humidifier;
http://www.essickair.com/pdfs/om_hum-400-console.pdf
If you don't find what you need in there then try;
http://www.essickair.com/service_centers/servicecenter_hap.htm
Hopefully they should help. If you still get no luck then please post back again with some more details of what you are having trouble with, maybe post some photos as well and we can try and help :)
