Question about Yakima Skybox Pro Cargo Box
My skybox is locked and it won't open. the handles just drop to the open position but the box is still locked. help!
Hatchback won't lock on saab 9-3
I had the very same problem with my 2002 Saab 9-3 after I manually moved the trunk latch to the locked position "out of curiosity..." Then I noticed there is a handle you can pull to release latch opening it up! Very simple remedy... It is a glow in the dark green plastic handle hanging down when the trunk/hatch is open dead center, just in slightly behind latch... Gently pull handle until you hear and see the latch click into the open position...Let me know how You make out. BTW: Toyota Camry has the same set up,same color as well...lol Good Luck!
Oct 16, 2012 | 2002 Saab 9-3 SE
Changed door handle but door still won't open from inside
which door is it cos rear doors have a kiddy lock-when you work the handle can you feel any resistance,as if the handle is actually connected or is it 'floating' ?
Jul 06, 2012 | 1998 Toyota Corolla
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
Mar 10, 2017 | 2007 Toyota Camry
Ba falcon door won't close
check that the lock mechanism is not already in the closed position
use a round bar under the latch and pull it into the open position as you press the door handle
Apr 28, 2012 | Ford Cars & Trucks
I need a diagram of the locking mechanism in my 2001 nissan sentra so that i can use a slim jim to unlock the passenger side door.
I don't have a diagram of the door but if you slip the slim Jim in over the top of the outside door handle it should catch on the latch bar. If you are doing this because the door won't open from the interior handle or the outside handle the problem most likely isn't the lock. The way that handle connects to the release it is held in place with a piece of plastic that breaks fairly easy. If that piece breaks the interior door handle won't activate the unlock function when pulled and you will have a heck of a time getting the door opened so you can get inside the panel to do the repair.
Oct 05, 2011 | 2001 Nissan Sentra
My trunk won't open, I have tried my trunk button and the key won't work, it worked fine a few hours, but even when i try to do it manually it won't open. Also I would look in and try the...
There are 3 phases to fixing your car's trunk lid release problem.
Phase 1: First check the fuse - once you know that's OK, then proceed to phase 2 (below).
The fuse for the trunk lock is
the bcm (pwr) 15A fuse in the instrument panel fuse box (behind panel at drivers right foot)
Check that fuse, as it is the power supply for the button on the dash that sends power to the actuator in the trunk.
Phase 2: Get the trunk open (without taking it to the dealership).
If you have remote keyless entry to the trunk, you could try that - but with the actuator
dead/dying, it shouldn't work.
Here are a couple of ideas to try to enter trunk while (a) actuator isn't working, and (b) all
valet lockout features (designed to deny valets access to the trunk) are in the "Lock" position:
There is the lock cylinder, which you stated is not functioning - put the key in, and it doesn't
turn. Just to be sure, consider: lubricate key with Graphite lock-type lubricant, and retry.
The trunk has 2 valet safetys...the locking rear seats which require access to the trunk to unlock, and then there is a valet switch in the trunk that locks the button on the dash from working to keep valet parking attendants out of the trunk. That may be in the lock position.
You can try accessing the center area of the fold down rear seat and see if you can unhinge the rear seat from there. Maybe reach in with your hand, or an extension-type tool.
there may be a way to fold the hinge away from the seat back so it can be removed from the hinge and give you access to the safety latch in the trunk and open it that way (white handle in trunk).
The white-handled safety latch release is desiged to prevent accidentally trapping children, and
if you can pull it with your extending-type or grasping-type tool, the trunk will open whether or
not the actuator motor is working.
Phase 3: Replace the Problem part.
Your failed part may be either (1) Trunk Release Relay, or (2) Trunk Lock Release Switch
My Satrun ION manual doesn't cover either of these parts, and the online parts houses, e.g.
http://www.rockauto.com/catalog/x,carcode,1431624,pgname,Electrical-Switch%2B%2526%252338%253B%2BRelay,a,search.yahoo.com%2BSearch%2Bfor%2B2004%2BSATURN
fail to provide instructions. One of those times a mechanic has to t=rely on his/her native
handiness and/or experience.
To identify which of these parts is bad, locae the Trunk Release Relay (call your dealer parts
dept. for helpful tips on finding it), then operate the dashboard trunk release button with your
ear close tothe relay - if it makes a noise, the problem is the Trunk Lock Release Switch in
the trunk lid, otherwise its the relay.
Aug 15, 2011 | 2004 Saturn ION
The drivers-side back door of my 1998 jeep cherokee won't close. The latch has turned too far and won't go back to it's open position so, unless there is some trick you can recommend, it will...
since the door is open,, hold the handle in the open position and try and move the little hook looking latch , it may have just moved into the closed position , if you can move it to the open position, then your home free
Jul 04, 2011 | 1998 Jeep Cherokee
Back door won't close
you can check the lock on the door isnt in the closed position(would sound like banging noise)
with the inner door handle pulled see if you can flip the lock to open on door. lubing doors once in awhile will prevent this
Jun 17, 2011 | 1996 Oldsmobile Cutlass Ciera
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
Hi
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
May 26, 2011 | Ovens
Driver's door won't open inside or out. Power locks work but inside and outside handles dont release latch. Can I get door panel off in the closed position, otherwise any way to open door
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
May 16, 2011 | Saturn Vue Cars & Trucks
Yakima Skybox Pro Cargo Box Logo
1,489 people viewed this question
Top Yakima Winter Sports Experts
Arnie Burke
Arnie Burke
Marvin
Marvin
Joseph Hoffmann
Are you a Yakima Winter Sport Expert? Answer questions, earn points and help others
