I have a error message when trying to open printmaster platinum 12
I'm trying to open printmaster platinum 12 and I get a error message the network user file, c/documents and settings/ALL USERS,WINDOWS/Application Data/Broderbund software/Print/Printmaster/PMusers, DAT, is currently in use. Can anyone help me. Thanks
  • 1 more comment
  • Anonymous Dec 05, 2008
    When trying to open PrintMaster Gold 15 I get the error message,
    C\Documents and Settings\All Users\Application Data\Broderbund Software\Print\PrintMaster\PMUSERS.DAT is currently in use. How do I solve it? I have no other PrintMaster programs running or installed.
  • cindyvl1 Dec 05, 2008
    I have the same error message in Print Master 15.
  • Roberta Smith
    Roberta Smith May 11, 2010
    do you happen to have other versions of their software on your computer ?
    Robert
    New Friend:
Use window search find the file and delete I did what was at support and it did not work I found this file in all users folder deleted it and all is well
Posted on Mar 09, 2010
Click on this link for a solution
http://support.broderbund.com/fix.asp?isid=34315&prog=1294820178&printer=1
Posted on Jan 04, 2009
SOURCE:
My printmaster platinum 2012 will not open.
Try re-installing software. For more detail on cause. Right click on My Computer > Manage > Event Viewer > Application and check errors / warnings based on source.
Aug 26, 2012 | Broderbund PrintMaster Platinum
I installed Printmaster 2011 platinum on my pc. Everything went well until I tried to print my project. I have an error message everytime that says: Printmaster 2011 Platinum 3.0.70 encountered the...
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
Oct 22, 2010 | Broderbund PrintMaster Platinum
Platinum 18 willl not open. Says I may need to reinstall printmaster and I am missing microsoft(r).network framework v1.1 Tried to reinstall printmaster and still doesn't work.
this is more than likely an issue witht the disc that the file is located on. I would contact the manufacturer and see if there is any way to get a replacement disc.
Apr 02, 2010 | Broderbund PrintMaster Platinum Version 18
PMSUER.DAT message on Printmaster Platinum 15
Have a look here.
http://support.encoreusa.com/kb.asp?id=144
Sep 12, 2009 | Broderbund PrintMaster Platinum 16
Cnnot open PrintMaster 17
Printmaster Platinum downloaded and installed reasonably well on my Gateway 6mb RAM 500MG HDD running Vista Home Premium.  The 26.5MB patch seemed to install okay.  In trying  to open the app I got the folloiwing:  "Error opening HKLM with ALL ACCESS - setting up registry"  I uninstalled--completely-- and the reinstall worked the same way with the same Error Message. The install followed the instructions that came with the patch via msconfig.  I can get the app to run with a lot of time-consuming effort using Task Manager.  Once opened it seems to work fine. It might be a good idea to offer a definition for HKLM, which is to say IHABT.  Oh, yeah, I HAD A ***** OF A TIME.
Presumably this is a registry entry or dll.  Please shed some light on this.  I have used this program for years and have a  host of saved projects.  PrintMaster Gold worked much better but I paid a bunch of money for Platinum (knowing full well  it was an older edition).
Help
Apr 06, 2009 | Broderbund PrintMaster® Platinum 17 Full...
How do I uninstall printmaster silver 12
the question was regarding PrintMaster Silver 12, although it was posted in the PrintMaster Platinum 16 forum.
Anyway, Broderbund has the instructions on their web site
http://support.broderbund.com/fix.asp?isid=30284&print=0&prog=1294819732
Oct 18, 2008 | Broderbund PrintMaster Platinum 16
Computers & Internet Logo
1,337 people viewed this question
Ekse
Alun Cox
