Rheem RTG-66DVN Direct Vent Natural Gas Logo
Posted on Aug 12, 2011
No hot water error codes 76, C4,C7 - Rheem RTG-66DVN Direct Vent Natural Gas
A
Anonymous
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Error-code-13.pdf
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
I have a poloma model/ pt62-42pvn its flashing error code c4 76 i have had no hot water for six days now need help
1) Before calling service technician who can test parts, open following link for Rheem resources including error codes, Rheem chat and phone number, possible manual:
If local technician cannot solve problem, Rheem can probably recommend a person.
2) Error codes are start-point for troubleshooting.
3) Multiple error codes can indicate PC board failure.
If your computer motherboard fails, most people feel the computer is compromised even after motherboard replacement.
4) Error code C7-76 is communication error with remote, and can include bad remote, bad wire to remote, loose wire, or bad PC board.
5) Error C4-13 can include part failure, vent problem, oxygen depletion, and can also include PC board failure.
6) Tankless routine maintenance manual:
7) Some posts about tankless concede that qualified technician was unable to repair unit.
Solve most tankless problems yourself, same day, for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
When taking a shower the hot water turns off. When I go to the tankless water heater it says C4 76. What does this mean?
Before calling service technician, open following link for Rheem troubleshoot resources including error codes and typical manuals.
C7 76 is problem with remote control. Following link might help.
Read manual cover-to-cover to make sure your tankless water heater receives yearly maintenance required for unit to continue working.
Tankless are maintenance heavy which can quickly eliminate any promised energy savings unless you de-lime and troubleshoot and read tips-and-tricks others have written and glean information from service technician who visits your house. Mostly glean how much tankless repairs and parts cost vrs buying whole new tank-type gas water heater at local box store, since all costs are energy.
My tankless is shuting off or flashing C4 and/or C7
Use following link for Rheem tankless troubleshoot: http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
I believe error code C7 is same as error code 76
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
6helpful
I also a Paloma tankless water heater that is 2 years old. I am now getting an error code C7 76 also. Is this something I can take care of, or should I call a plumber to address?
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support .
If this helps, please indicate so.
Mike//jzklipper
7helpful
2answers
Remote is displaying C7 76
Contact Paloma/Rheem customer (800-432-8373) support and notify them you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support. However, I do have a detailed process on how to repair the printed circuit board yourself. Any further questions, you're welcome to email me at [email protected] .
Good Luck, if this has helped you in any way...please indicate so.
123helpful
11answers
Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
25helpful
7answers
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
