SOUNDS LIKE TWIST GRIP ON HANDLE BAR IS STICKING REMOVE IT CLEAN INSIDE IT WITH WD40 IF THIS DOES NOT CURE IT STICKING YOUMAY NEEDTO REPLACE IT GOOD LUCK
Testimonial: "Thanks alot I`ll try that and see what happens if it doesn`t help I`lllook for a replacement, Mahalo John"
DID THIS CURE YOUR PROBLEM/?
It helped alittle but I still have to turn the throttle backwards to turn it off . The throttle is not isolated by itself it also houses the front brakes ,a kill switch, headlight and taillight switch. this is on a 2002 Voloci electric bike and I`m unsure about replacement parts? Thanks John.P.S. I`d like to match new parts to the old and not mix it up.
