Dv2000 zero support now at hp,
2006? year.
so does the VGA port on the rear of PC work. to a desktop monitor
yes, then the mobo is ok. but not screen.
easy no?
i can make the mobo run on a table. vga connected.
with Fn+F4 toggled on and external USB keyboard, I can activate the external screen.
steps. are as follows. in proper order
1: remove that shorted huge battery, there. get it out of there.
2: make sure the power pack reads (VM) 19vdc at the jack.
3: new coin cell if voltage on its pins below 2.9v... yah?
4: get BIOS screens working FIRST. disconnect HDD and DVD drive. now.
5: go to 1 ram stick bank 0 (try 2nd one by self)
6: does the flashlight trick work on that CCFL screen,?
7: remove all modules from MOBO cept CPU and 1 stick RAM?
we call that the strip down tests.\
8: beep codes, or Caps lock key flash codes? what?
BIOS screens have to work, or mobo is dead.
has anyone been playing with BIOS doing crazy things like flashing it.>? yes, oops now you bricked it. then what (ask)
if pc is 2008 that is the solderball from hell year.
see that and the CCFL test here.
http://www.pcdied.com/monitors.html#flashlighttest
so its an old laptop.
does it run with the battery (main large) out;
this always 1st test, after all they love to short cells inside.
next are BIOS screens. we get those working first.
or all else is doomed, see?
BIOS screens work with hdd and DVD drives removed. see?
F11 will be dead sure, with any HDD remove so forget F11 for now.
F11 is HP restore.
does the mobo beep codes.
does the CAPS lock LED lamps flash codes?
if you remove all mobo things cept CPU and RAM 1 strick
does BIOS work,
if all that fails try a new 19vdc 100w (65w min) power pack,
if the shop voltmeter shows 19vdc at the mobo jack
then its ok and mobo bad.
the above I do with external VGA monitor connected, fn+F4 toggled.
LCD , bad
if only the LCD is dead, (means to me never any text ever)
just it dead, then we
first see if pc is 2008 PC, the solder ball from hell PCs.
the DV2000 up have CCFL lamps
that all die soon. all do. go dim or dead.
so does the flash light trick work?>
see the flash light trick>?? (DEAD CCFL tubes) back lamps dead.
http://www.pcdied.com/monitors.html#Lapt...
that PC has VGA port on the rear, it sure does work
even with bad screen inside.
id be all over VGA, what if that works perfectly?>??
carbon dated, i see 2006 reviews on said PC.
so it may be Solderball failure free.
this PC is retired ( obsolete ) at HP.
see this, all modules pulled
cpu, there ,1 stick ram. the screen is stock internal screen
but i can remove it and plug in any desktop screen on the
rear.
the USB keyboard on mine, the BIOS keys all work
i press ESC then F1 to get hp info screens (any one)
the fan must spin, under BIOS
if not its packed in lint or power pack is bad. (in most cases)
note case is missing totally here. its SPACE PC we call it.
SOURCE: Front panel connections
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
SOURCE: My Intel D102GGC and Mercury 915GLV motherboard not wake up
Is this new ram or have you used it in this machine previously?
A couple of things can cause what you describe, one of them being the wrong voltage of ram. This page contains the list of memory that your system can use, check the part number on your current ram in google to find out what voltage it runs at (the recommended voltage for your board is 1.8v).
Other than that you may want to do a CMOS reset by changing the jumper block (should be described in your mobo manual), powering the machine on briefly, power it down (unplug) and return the jumper to it's original location. Now try to post the machine.
SOURCE: The hp pavilion dv2000 not booting
You might be still covered under extended warranty, check here
SOURCE: I have a Emachines w2888 my PWR S/W ,PWR led &
http://img406.imageshack.us/img406/8789/56743980.jpg
try to search here...P and Q port if theres an indicator for the s/w and leds....
Your DC connector on the system board is loose:
Problem symptoms:
If it is under warranty, HP will repair it. If not , read this:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
