Posted on Aug 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dictaphone Model: 7120...Power Supply Part#: 870403 fried one of the Voltage Regulator IC's. I am looking for a Schematic or Service Manual for this unit. It seems as if the company disappeared from the planet. If I can get this documentation, I could Identify the part and repair the unit. Taking a guess could be more expensive. I am willing to pay for the Service Manual.
Anonymous
Level 3:
Guru:
  • Master 586 Answers
  • Posted on Aug 12, 2011
Anonymous
Master
Level 3:
Guru:
Answers
586
Questions
0
Helped
211652
Points
1670
Hello there,
At times companies that produce devices like this tend not to put the manual online and efforts to try to get it through some other users upload might be difficult as well. The solution is for you to simply just disassemble the device and try to locate the fried regulator.
That way, you will be able to solve the problem, The moment you disassemble the device, you will be able to detect where the problem is from and know how to solve the problem from there.
Most times, the service manual just do not give prescription and direction on how to repair problems like this as the kind of solution the proffer there are basically common problem that requires just pressing just one button or the other on the device.
Try to disassemble it, that way you will be able to diagnose, detect and fix the problem as the case may apply. But if you do not want to disassemble it, you can get it to a repairman to have it checked and fixed for you in order to save you the expense of a guess work.
Hope this information was helpful to you. Goodluck. Elect_Comp
2helpful
Hello i need schematic diagram for power supply Model MEGMEET - ML686 . that power supply used for LCD TV .it's bad Brand and nobody care in service center. hope somebody help
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check the present power supply [SMPS]; and find out the number of switching regulator IC used. Surf the site with that IC number. You will get similar circuit for SMPS there.
6answers
I need to adjust the voltage regulator in an attempt to minimize the "red spotting" on the screen in very dark areas. I was told this is the first step prior to replacing the video card. How do I...
You are going to need a factory repair manual before you even should attempt this kind of repair, you say you heard this from whom? if you get it wrong the TV voltage adjustment can burn out other circuits, leave it to the pro's to deal with an issue such as this.
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
3answers
Mitsubishi VS50605 Ser# 101189 This unit does not have the Lg. DM module on the left of the main Bds.(2) It first stopped turning on with the remote then after a month or so stopped turning on...
I have read your first comment and you have said that there's some instances that the unit power up by repeatedly turning it on and off.
This kind of symptoms is an indication of out-of-regulation condition in the power supply section. It was caused by leaky/dried filter electrolytic capacitor in that section. It will dropped the supply voltage and will disable the unit. In the first stage of the symptoms, warm-up will make itself stable but it will get worst, time will come that the unit will not even power up at all like what you've experienced right now.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can be easily identify like in this sample picture.
Dried electrolytic capacitor has no physical indication of fault, you must have a capacitor checker/tester to determine its condition.
Check the filter electrolytic capacitor most especially in the supply line of the relay, and in the voltage regulator IC's circuitry.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
How to make regulated power supply
The easiest way to do this is to use a 3 pin regulator IC.
For a 5 volt supply go to this WEB site,
http://schematicwiring.com/simple-electronic-applications/5v-dc-regulator-with-3-pin-regulator-circuit-schematic-diagram/
For a variable voltage power supply go to this WEB site.
http://www.engineeringslash.com/power-supply/three-terminal-adjustable-regulator.html
4helpful
2answers
Mixer not working and board getting hot
There is likely a voltage regulator or a diode burned out in the vicinity of the power supply. If you have the schematic, start at the power supply and work through the circuit to the I.C. Also look up the pinout on the internet for that I.C. With the power on test the voltages at each pin on the I.C. You should not have supply voltage readings on any of the signal pins. This is an indication that the I.C. is also burned out. Use a volt ohm meter with a D.C. voltage setting. Also hopefully your meter should have a diode test function. If not you can still test them with the resistance test function.Here is a link to an explanation:http://www.elexp.com/t_test.htm I hope this helps.
I plug in my casio ctk-800 and it does not turn on when i press the on button
If you lucky, the power jack may be at fault since it switches from external to internal battery, but most likely the internal supply is what's damaged... IC regulator possibly. A quick voltage check with a volt meter at the power leads on the main board will verify battery or xfmr supply voltage, if voltage is present then look in close proximity for an IC regulator and check for an output.
1helpful
Tv turns off after about 5 minutes
I looked for that model but it isent in my data banks?? You should try to get a service schematic on the set first. Next look in the power supply and find the power supply main regulator IC. Hook up a meter to the output pin and turn the set on. If the voltage is slightly exceding the value of the IC wait and see what happens . Now right before the set shuts down, does the voltage swing high?? If it does its the IC. It should be a 125 to a 135 volt regulator and if it goes higher then 130 to 140 its bad as I said. If this voltage dosent change then the problem is in the High voltage section. Find the sweep Ic and locate the x-ray protection pin. Monitor the voltage on that and see if the voltage swings high when the set shuts down. I it does your gonna need to check out parts in the horizontal sweep circuit and if you got a scope use it. But remeber always use an isolation transformer when trouble shooting these sets or the meter or scope could blow out the power supply . Good Luck and Be carefull
Top Dictaphone Audio Players & Recorders Experts
NOEL
NOEL
diyfixtool phonefix
diyfixtool phonefix
Adviser101
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
