I have been looking around for a way to reset the timing on my sewing machine and I came across a response from you. Can you help?? So far my only solution has been the local repair shop. The Model is actually a EURO-PRO Shark Model 9110. I could not find the exact match below. Thanks.
Needle hook timing is set when the needle in the full down position has the bobbing carrier hook approaching the needle
AS the needle starts to rise the hook is at or just about at the eye of the needle
The adjustment is on the needle cam lever at the end of the machine and on most , there is a clamp around the shaft that is loosened of , the clamp tapped up or down to achieve the correct setting and re-clamped
SOURCE: help me find a manual for a euro pro 7133 sewing machine
Contact Shark @ 18003614639 they will send you a manual. They were very helpful and courteous.
may we all find some peace in thse manuals.
SOURCE: looking for a owners manual for a shark euro pro
If you want it free, try here first. You'll need a specific # off the back of the machine, they tell you where to find it.
If they don't have it online, you'll have to pay for one.
http://www.euro-pro.com/europro/default.aspx
SOURCE: I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
SOURCE: won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
SOURCE: Shark by Euro-Pro X 384 Sewing Machine Manual
Callo 1-800-361-4639 and you can buy one from them for $4.95.
I have a Euro-Pro shark and it broke a needle and won't pick up the bobbin thread. I think I need to reset the timing can you tell me how to do that?
