The first thing I would check would be in the configuration (point your web browser to 192.168.1.1 when you have a wired connection) panel, under:
Wireless settings > configuration
If the 'Wireless mode' is set to 'SuperG', this may be your problem. The SuperG setting will only work with SuperG enabled wireless adapters. First change this setting to 'Mixed 11b/11g'; if it still doesn't work switch down to '11g' then to '11b'.
Do all your wireless testing with a laptop or PC as close to the router as possible - same room at the very least.
If all other settings are correct (double check them), this is the only thing I can think of that can instantly make a difference.
If you feel the firmware may be faiilty, note that although 3.0.1 is the 'newest' on the 3com website, even in their own knowledge base they refer to newer versions. These newer versions are available at:
http://3crwdr.googlepages.com/You could try using one of these (at your own risk), if you feel it is the firmware itself that is causing the fault.
