Setting the router's administrator password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions. Setup steps: Click "Apply Changes". Your new password is now active. Note: Do not forget the new password and keep
it somewhere safe. If you forget your password, you'll be unable to
access your router's settings. If you forget or lose your password,
you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Boot up or restart your Toshiba laptop.
Immediately and repeatedly tap the F2 key on your keyboard until the start screen appears to change your BIOS (user) and supervisor
(HDD user) passwords.
Use the arrow keys on your keyboard to highlight "Set User Password" or "Set HDD User Password" and press "Enter" on your keyboard.
Type the current password in the box that appears.
Type your new password ox.
You will be asked to enter your new password a second time to confirm it.
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
