Usually when this occurs, the unit "thinks it's full', because either the water collection bucket is not installed properly or the float valve (if you model has one) in the top of the bucket, is stuck in the "UP' position.
Turn the unit OFF & unplug it. Remove the water collection bucket and check for the float valve. If it's stuck in the UP position, jiggle the handle to make it return to the DOWN position. Then reinstall the bucket, being sure that it fits into it's holder "squarely" from top to bottom and is making firm contact with the Bucket Safety Removal Switch on the rear wall of the bucket holder. If installed properly, the bottom of the bucket should not tilt down at all. Plug the unit in and turn it ON. If everything was done correctly, the Full Bucket Light should not illuminate.
Hope this helped you and thanks for choosing FixYa.
