Download the user manual here Brother mfc 255cw manual
SOURCE: Printer spits out blank page before printing
Check Your Ink Catridge. If the Catridge ink is full then try the following Steps.
Hope this help. Please Rate My Response! Thanks!
Prem
SOURCE: Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers.
Remove the printer.
Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight.
If that does not work, then the printhead must be replaced.
Regards
SOURCE: Printer prints blank pages
The print head is a part of the printer itself and unlike other printers, you cannot remove it or soak it without ruining your printer. So just try the print head cleaning option and perhaps replace cartridges, especially if you are using a third party or refilled cartridge which can clog even if it is full.
