Question about Mitel 5212 IP Phone
Hi there, How do you remove 'Do not Disturb' on a Mitel 5212 handset. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Hit the blue button (Superkey). hit no until you see DND and you can turn it off or on. If you don't see if you have to login to phone system and get feature access code.
Posted on Sep 17, 2011
SOURCE:
Problem with Mitel 5212 IP Phone
Need to login to. The phone system and change it back.
Jun 06, 2013 | Mitel 5212 IP Phone
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Dec 13, 2010 | Mitel 5220 IP Phone
Cannot get incoming calls on my Mitel 5212 IP phone. When my colleagues phone internally, they get the "NO DISTB" message.
Your phone is in Do-Not-Disturb. Press the blue superkey. Press No until you see DND or Do-Not Disturb and press yes... press Turn off.
on this phone, the * and # are the keys for yes and no.
Nov 11, 2010 | Mitel 5212 IP Phone
Hi there How do i reset the PIN on the mitel 5212 IP phone? Thanks
Contact your system administrator or vendor. They should be able to clear this for you in the system.
I cant receive calls in my mitel 5212 ip phone
is Do-Not-Disturb enabled? Press the blue superkey and press no until you see DND. Select Yes, and turn off.
Jul 30, 2010 | Mitel 5212 IP Phone
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
Two lights on phone mitel 5212 ip phone
It sounds like your phone is in do-not-disturb. Press the blue key. Press the no (# key) until you see DND, then press Yes (* key). Press Turn off (0 key).
Apr 07, 2010 | Mitel 5212 IP Phone
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
Call divert
You can use the superkey
Phonebook - No
Advisory msgs - No
call forwarding = Yes
Allways = Review
from there you can select the extention number you want to forward the calls to. Having done that you need to turn on call forward always on. I do this by using one of the programmable keys on the Phone
Jul 07, 2009 | Mitel 5212 IP Phone
Trying to program a touch for incoming calls that will go through my voice mail directly
This can be handled by the DND feature in your admin settings... Do not disturb will transfer your calls direct to voicemail without ringing the handset.
May 18, 2009 | Mitel 5212 IP Phone
Mitel 5212 IP Phone Logo
322 people viewed this question
Top Mitel Computers & Internet Experts
Daniel
Daniel
Vincent G
Vincent G
Gil Shultz
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
