Cell Phones Logo
Posted on Aug 11, 2011
How do i change the number of rings before voicemail picks up on a samsung rugby
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1148
Points
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Aug 11, 2011
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
6681
Points
40
You can get the details in user manual....
  • Anonymous Nov 10, 2011
    Thanks a lot for all your help.
How do I change the number of rings on this phone?
The KX-TG2313 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count, refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
Voicemail number changed on samsung galaxy and can not check voicemail now
Voice mails are set up from the phone company. Your phone has no control over the voice mailing service other than assigning a speed dial to it. You should call your phone company on their customer service number and they will tell your the number to call for setting up your voice mail box.
Mar 11, 2014 • Cell Phones
2answers
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
1helpful
How to change the number of rings on my cordles telephone TRU9260 series
The ring count is controlled by the answering machine or voicemail system on your phone line. The TRU9260 is just a phone, it will ring until your or the answering machine/voicemail system picks up.
What answering machine/voicemail system do you have?
Number of rings before voicemail picks up
What make and model phone/voicemail?
Trying to change number of rings before voicemail picks up
This is done in station administration. F config side of the system. Do you have access to system programming?
Number of rings before voicemail answers.
go into menu the look for sounds and ringer tones .then u should be able to listen to the different kinds then pick one u like .then u save it!!!
3helpful
# of rings before voicemail picks up
Yes there is, but you have to know multiplication :-)
At the extension, from the intercom dial *713 and the 2-digit time in seconds. An internal ring cycle is about 6 seconds. I think the default time comes from the system and it may be 40 seconds.
Carl
1helpful
Change the number of rings - Samsung D500
This is a network related setting. Do the following.
from your home screen, type "* 61 * (voice mail access
number) ** (time in multiples of 5 ) #" and then press SEND. For
example, if my voicemail
access number is 404-555-1212 and I want it to ring for 20 seconds
before forwarding to
voicemail, I would type: *61*14045551212**20#
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
