My Canon ipf8000 stops printing (or doesn't start!) giving me the error code Hardware Error 03130031-2F13. The print head stops dead midway across the print and forces me to turn on & off. On restart the nozzle check & clean is performed.
Thanks for any help.
03130031-2F13 A/D Converter external trigger output stopped
and the problem is main controler
Lol,, see this
We have an IPF700 and have been getting the 031300312f26 error alot upon warm up. We have found to fix this problem the best option is to push the print head back to its home position (far right) and unplugging the printer for 1 min or so (just to make sure its memory has lost all awarness we messed with it). Then plug it in and it goes fine... The problem we used to have is the same many of you are complaining about it drains ink like a vampire whenever you have to restart it. To cope with this we have upgraded our firmware which has drastically decreased the amount of ink we waist due to less cleaning and agitating functions. Hope this helps out someone it took us a while to get back any love for the canon but we are comming round again (I mean it worked great for 3 years why give up on it now).
Just had this happen and I replaced the ribbon cables from the controller to the carriage unit. Also had 03130031-2f26 intermitently. This is not a fun job but the problem has not returned.
The same problem happens here with ipf700.
I got an error (03130031-2F13) which required me to power off and wait, then restart. I did so only to get another error but slightly different number (03130031-2F26).
Does anyone know what this means and how to fix it?
I've the same problem with my IPF710, on every print I've got the same stupid and very irritating message "Perform print head cleaning nozzles are clogged", but the printouts are perfect? Canon service suggested pf-03 replacement, but printhead is almost new snd Canon doesn't want to replace it on warranty. This technology sucks/
i have exactly the same problem. Canon is absolutely no help. Tec Graph are the biggest ripoffs yet. Help.
fer_nan_14
What is the solution?
I have the same problem on my ipf9000
These machines are **** and the replacement parts end up costing $ 1000s. The errors on these machines can mean anything. So far the tech has replaced many parts and I still have the problem. Meanwhile, every time the tech replaces anything the machine empties a third of every bloody ink cartridge and fills up a maintenence cartridge. I have gone through 7 maintenace cartridges in the last 3 weeks.
Pete
Create-Design
Cairns
Australia
Do not buy a canon wide format unless you have extended warranty ----say 10 years?
i have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- [email protected] for questions and support
good afternoon, do you have the firmware to unlock canon head signal ipf 755? How can I opt?
I am looking forward to your response.
Greetings.
good afternoon everyone
I'm having a problem with a canon ipf750 plotter error code 031300-2F13
I have done the cleaning according to the manual and I have changed the sensor management, PF04 head and maintenance cartridge but the error code continues,
The strange thing is that in the mode of service if it prints normal all the tests and verification of nozzles does not have problems, the rare thing is that in the normal
