Question about Jabra BT650 Bluetooth Headset Halo
Just bought jabra halo and am chagrinning it it has been 2hrs and it the red light is still flashing or is just not on at all what do l do
    New Friend:
How long does the manual say to charge it for? usually it's several hours before you can actually have a full charge on the first use
Posted on Aug 13, 2011
SOURCE:
How do I pair it with my phone? i lost the manual If I just turn it on, it my cell doesn't seem to find it. It says to put the Jabra in discovery mode. How do I do that? Also, do you know how I can...
Christine,
To put the Jabra in discovery mode, turn it on and hold the answer/end button for five seconds until the bluetooth light starts flashing and it announces "pairing mode." Then connect with your cellphone!
You can order a new charger for your car/computer from this link:
http://www.buyjabra.com/US/accessories/universal-charging-kit-car-usb-136.html
Or, for your wall from this link:
http://www.buyjabra.com/US/accessories/us-wall-charger-for-bt530-jabra-halo-144.html
Best of luck!
- Zach
Mar 05, 2011 | Jabra Cruiser InCar Speakerphone Black
Jabra BT650 won't turn on. green light blinks only while charging.
For a while I was not able to figure out how to turn the Jabra Halo headset on. What you need to do is unfold the headset and then push the hinged portion into itself, which will lock it in place so that it will no longer hinge for the time being.
Oct 14, 2010 | Jabra BT650 Bluetooth Headset Halo
Jabra Halo Headset doesn't turn on
It wont come but yesterday it was just working fine what do I do
Sep 04, 2010 | Jabra BT650 Bluetooth Headset Halo
Jabra red light of death
seeing the red light tells you that the jabra isn't fried or shorted and that there is life but there is a problem, the red light isn't blue when it should be. so have you read the directions your ear piece came with when you first bought it?... hold the on button until you see the blue light stays on.(blue light will flash fast then slow then come to a complete stop and stay on) once blue light stays on that should mean you can now find the ear piece on your cell phone to link up. if problem still isn't fixed then you might as well buy a new one.
Aug 04, 2009 | Jabra BT350 Bluetooth Headset Headset
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
The flashing red light comes on with message E74 . What can i do?
It is because The hard drive is spoil if u remove the Hard drive and blow to the hard drive the red light will not come
May 17, 2009 | Microsoft Halo 3 for Xbox 360
BT500V won't charge
This happens because the battery gets too low to take a charge.
To jump start the headset, connect the power lead and the LED will be flashing red. now press and hold the power and BT pairing buttons. The LED should change to solid red.
I found that holding both buttons for about 3-5 minutes allowed the battery to get enough charge to start charging and you can release the buttons and the headset will continue to charge.
If the led starts flashing again, just repeat the process again.
Hope this helps...
Baz
Dec 16, 2007 | Jabra BT500V Wireless Headset
Jabra BT650 Bluetooth Headset  Halo Logo
366 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
