Flotec 3.4 Hp Floodmate Submersible Sump Pump Logo
Posted on Aug 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sump Pump is running and wont stop. It usually go for like 30 seconds a few times per day, but it wont stop. I unplugged it and waited 30 secs, plugged it back in and it's still going. Any suggestions?
Anonymous
Level 3:
  • Master 990 Answers
  • Posted on Aug 15, 2011
Anonymous
Master
Level 3:
Answers
990
Questions
Helped
468954
Points
2217
Check your float and the switch. It sound like it is just sticking. If it were bad the pump probally would not start
2answers
1991 Ford F150 problem - please help me
Check the fuel pressure from the pump.
2answers
1000W EverStart power inverter. Tested it when I bought it on a lamp, and worked fine. Now months later, today, I needed it to run my 5A sump pump and it worked fine to fill two drums.
My guess is it overheated and shutdown or crowbared output due to overload.
Are you sure the sump pump uses 5A. Suggest you measure actual current delivered from the inverter.
Unplug everything shut it off and wait a few minutes and see if the inverter recovers.
Can you explain what 10 second video clips at 30 frames per second mean?
It means that the video will last 10 seconds. 30 frames/sec is the quality of the video. It is the number of individual pictures take per second. Example: 10 frames/sec produces a jerky video but is sometimes used for security monitoring. On some cameras you can reduce the frames/sec to get a longer running time.
May 25, 2015 • Cameras
Changed fuel filter on my 97 century with an m11 wont stay running
make sure its on correctly... some filters only flow one way. check to make sure you didnt inadvertantly disconect the fuel pump or pressure regulator. (you should be able to hear the fuel pump hum for a few seconds when you turn the ignition switch to on)
Need to know why a 97 mercury cougar won't start until cooling fan and fuel pump stop running
I would think it's a problem with (CCRM) constant control relay module . This module has relay's inside that control the fuel pump , cooling fans , A/C compressor clutch , PCM - engine computer power relay . And thier are electronics involved , solid state circuity . Google CCRM
found this helpful answer from mercury mechanic on JustAnswer com
I have not received any emails for over aweek. I usually get 5-10 per a day.
And you think this is a problem with your router? That has nothing to do with your router if you can still surf the web just fine. Try restarting your router by unplugging it waiting 30 seconds, then plugging it back in and waiting another 30 seconds. This solves problems with a router 9/10 time.
Best of luck
Takes multiple times to start
I think you have a faling fuel pump or a bad pressure regulator allowing fuel pressure to bleed down when the engine is off.
Try this test - When you start the car for the first time of the day, turn the key to "ON", wait a few seconds, turn the key off. Wait about 15 seconds, turn the key to "ON" again, wait a few seconds. Then wait one final time for 1 seconds and try starting the car. If it starts right away, that means fule pressure is bleeding of due to a bad check vavle int he fuel pump, a bad fuel pump or a bad pressure regulator.
The reason for the procedure is because when you turn the key to "ON", the fuel pump runs for 2 seconds and then shuts off if the engine is not running. The 15 seconds wait is for the power and fuel pump relay to cycle off before it will run the pump again.
Let us know how the test comes out. The fuel pump is in the fuel tank and hums when it is running.
I have a 95 Maxima I changed the fuel injectors and now the car wont start.  so i put the old injectors back and it still wont turn over,  It stay on for about 2 sec can anyone help me
I assume you bled off fuel pressure before you installed the injectors. Try this to pressurize the fuel system. Turn the key to "on" position and wait 5 seconds. AT same time, listen carefully for a buzz sound that means the fuel pump is running to pressurize the system. It will shut off after 5 seconds. Then, turn off the key and wait 30 seconds for the computer power relay to shut off. Then, turn the key to "on" again. Thsi will run the fuel pump for another 5 seconds. Repeat 5 times. Fuel system should be pressurized now.
If it doesn't start now, you may have done something while you were changing the injector. good luck
Top Flotec Garden Experts
Jay Finke
Jay Finke
Paul Katynski
Paul Katynski
David Spradling
David Spradling
Are you a Flotec Garden Expert? Answer questions, earn points and help others
