Question about Carrier Heating & Cooling
I have Carrier Comfort Zone 2 on a York system. Everything has worked fine. After recent lightning strike, the controller is not responding correctly. It flashes E1 alternating with the current temp. No matter what the programming, it seems to start cooling when the house gets to 84-85 degrees inside and then stays on continually until it hits the programmed 76-77. How do I test to see if zone panel or thermostats need replacing?
    New Friend:
This <a rel='nofollow' href="www.curthel.com">carrier</a>
has everything to quickly and safely deliver your <a rel='nofollow' href="www.curthel.com">car</a>.
Posted on Nov 05, 2013
SOURCE:
  • 38 Answers
SOURCE: Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Posted on Jun 30, 2009
  • 334 Answers
SOURCE: carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Posted on Jun 27, 2009
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
  • 614 Answers
SOURCE: Carrier Comfort Zone 2 Master is flashing E5
Check float switch. E5 is loss of 24 volt power on some models.Russ
Posted on Jul 27, 2009
  • 10 Answers
SOURCE: We have the same problem, was hit with lightning and came up E1
You didn't get a Carrier tech. Carrier technicians only work on commercial equipment. Residential applicaitions, installation and service of Carrier residential units are done by dealers. They are not carrier owned but get buy the product at discount get training and get to show our logo. You can't fix the boards, they have to be replaced. It sounds like you have a Gen II VVT system. You can get the part via Totaline stores or a distributor. You will need to know how to readdress the other controllers to operate correctly. Use WWW.Carrier.com.
Posted on Oct 21, 2009
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
Feb 16, 2018 | Carrier Heating & Cooling
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 15, 2017 | Heating & Cooling
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
Aug 03, 2009 | Carrier 38CKC060 Air Conditioner
Jul 27, 2009 | Carrier 38CKC060 Air Conditioner
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Jun 24, 2009 | Carrier 38CKC060 Air Conditioner
Ethernet Port failure on Acer Aspire T180-GB7Z
Type of your O.S (Operating System) Windows, MAC, Linux Etc?
May 12, 2008 | Acer Aspireā„¢ T180 PC Desktop
Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Jan 28, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
315 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
