Sony HDR-SR12  HDD Camcorder Logo
Posted on Aug 11, 2011
My HDR-SR12 handycam automatically switches to night vision when it is turned on & stays in night vision. Doesn't switch back. I bought it used, & have been filming with it fine since I got it 8 months ago. The problem started recently. Didn't drop it or have it exposed to the elements. Can you help??? Thanks.
Anonymous
Level 1:
Genius:
  • Contributor 1,812 Answers
  • Posted on Aug 11, 2011
Anonymous
Contributor
Level 1:
Genius:
Answers
1812
Questions
0
Helped
251619
Points
49
This is a failure of the cameras internal "night vision"switch which is part of the lens assembly. the camera will need to be disassembled to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Hdr fx7
Here is a helpful video going over the problem you are having.
Sony hdr sr12 screen won't open
HI,
A component called hing needs replacement.
Hdr sr12 powers up but shuts down after a minute and keeps shuting down after each time i power it up.
I Can Only Say Make Sure Your Battery Is Staying Charged Cause You May Have A Bad Unchargeable Battery
HDR-SR12 - LCD Touch screen very dim , screen works but almost completely dark. tried increased brightness etc no help
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast.
Search ebay for an HDR-SR11 or HDR-SR12 flex cable similar to this one:
http://r.ebay.com/L4dWDQ
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I'm doing mine myself. Results to follow, maybe, if I remember to post following the repair.
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast. With the right external light you could sort of make out what was on the screen by back reflection of what was on the LCD screen.
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I did mine and it works excellently. An $8 cable and about an hour (plus a lot of pictures-as-you-go for reassembly) is all it takes.
My pvs7 wont stay on thay shut of after 30 seconds and then start to shut of ever few seconds
Hello, have you or someone else pointed this night vision devise at bright lights, street lights, head lights. If so, maybe the damage has/hasn't alread been done. STOP. This PVS-7 goggles with ITT image tube with generation 2 or 2+ or possibly generation 3 tube. The devise is an American made unit, and the best in the world. Nobody can compete with the USA on NV. They sat the standards on Night Vision.
Have you replace the 6 volt battery? Get the goggle in a darken room then turn the switch on.
see if the 25mm plate will turn green and stay on. But first replace that battery.
Therefore, if this test works, then never and I mean never shine NV devises into bright lights, it will destroy them every time.
PS. send me another message and let see what happen. stewbison
I need the instruction manual. Also, what is the top red light for? Just what does it do
Hey, you got you self a Russian NV monocular. There should be two switches. One switch is to turn on/off the unit. The second switch is used to turn on the IR illuminate--which means infrared red light. To improve the night capabilities of the NV monocular. Ther are two LED's one green for on/off switch and one LED that is red for the IR illuminator.
NO-NO-NO's
When the NV monocular isn't been used, take the batteries out. The worst NO-NO's is looking through monocular during the daylight hours. The do have metal front lens cover with a small hole in the center for a few minutes of viewing during the day. Remember---Use Only During the Night---Do look at bright lights, don't let the kids play with it and make dam sure that Grandfather doesn't get his hand on it. He will be doing long range peeping at the neighbors or the lady that leaves here blinds open during the. Kid-No, Grandfathers-N0, Fathers-that up to them. If pop going some night look see. I'll make a bit his survival ratio has raised demise by 70%. stewbison
I bought a used sr12 Sony camera, and need a manual.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HDRSR12&LOC=3
How do I "see" the Pro Duo card in the Sony HDR-sr12E Handycam on my PC. Can see the hard disks with photos and videos etc but not the card.
The camera is probably configured to record to harddisk now. Select your Pro Duo memorystick as the record media thru the menu's (select the memory stick icon), and you'll be able to see the stick content.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
